Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Another Cooling idea from a dreamer...
  1. #31
    Dec 2002
    Illinois
    Well since hes already running the water cool system, why not run a cooler over whatever is disapating the heat from the water. I dont think hes going to get around the condensation problem without being able to remove moisture from the air residing inside the computer there was air cooler concept i worked on the air force that used cotton absorbers to remove moisture so that it wouldnt damage the aircraft electronics but I dont think I have the schematics laying anywhere close.
  2. #32
    Nov 2004
    NY tri-state
    Wow that's a long post...
    Quote Originally Posted by evandude
    and as for the suggestion of pumping AC into the computer directly instead of water cooling:
    well, in that case there's two concerns:
    1) the radiator and water combination are probably more efficient than the CPU heatsink and fan... since the water cooling is reasonably efficient, and the radiator can be significantly larger than a CPU heatsink.
    Perhaps so, but like I said before, water cooling in a closed, warm environment (like your trunk) doesn't do jack. When the ambient air rises that much, the water cooling is not going to do anything at all, regardless of how efficient it is. You could increase the size of the reservoir, the size of the pump and the hoses, and even the radiator and fans. If the radiator doesn't have anywhere to dump the heat -- because the trunk/room is too hot, then it will little by little start removing less and less heat from the CPU.
    Even if your CPU is 100-120°F, the inside of the trunk is what? the same or hotter on a hot summer day? At that point the radiator is hot, the air in the trunk is hot and the "coolant" in the reservoir is hot. Not much heat can be dissipated in there without getting some part of the loop out of there.
    2) condensation. if you've ever had your AC on full blast on a hot day and had one of the vents aimed toward a window, you probably know about this. hot CPU heatsink + cold air is a recipe for condensation. Therefore, you can isolate it by cooling the radiator instead. (which could be away from the PC, where condensation wouldn't matter)
    Good point, but unless you run arctic temps inside your cabin, I don't think (IMO, obviously) that you'll have to worry about condensation. What I'm talking about is ducting air from the cabin into the trunk... or even directly onto the HSF to keep it cool (chipset and video be damned! ). If you blast AC directly onto the mobo, then you might have a problem -- if you like running the AC at 50° full blast or something, but otherwise I think it might be ok.
    Now we just need a guinea pig.
  3. #33
    Oct 2004
    NY
    I don't think you'll need a thermostat on an install like this...tranny coolers are perfect for this...I've done it before...... copper tubing front to rear isn't that expensive.... you will have to go big bucks on a pump though.....
    if the computer is in the trunk you may be able to find a spot under the vehicle..... but it must be in airflow & not get damaged in use..... every car is different & every heat load is different.... I once water cooled an amp in the trunk.... used a copper radiator tube with finns..... mounted in a frame rail... worked good
    of course you could always put it inside in a quarter panel & build an air duct into the quarter ala mustang style.... "whats that air duct for"....."it's for the liquid cooling system for my computer"
  4. #34
    Nov 2004
    NY tri-state
    I'd be more worried about running the tubes through the engine bay though. even if they aren't too close to the engine, it gets pretty hot in there, and if 6 or so feet (firewall to bumper vent to firewall) of the tubing was exposed to that heat, you'd be losing a lot of efficiency... perhaps if you ran them way off to one side, and put some form of insulation on them...
    Or mount the radiator like you would an intercooler, under the main radiator, and pipe outside of the engine bay -- weld it or bolt it onto the underbody somehow. But then you'd have to worry about debris from the road...
    I still think the car has a perfectly good cooling system that's just DYING to get used... and you don't have to worry about maintaining two cooling systems (the car's plus the computer's)...
  5. #35
    May 2004
    With the peltier devices, they use ALOT of power and create condensation, so in the long run you need to have watercooling for the PC, or its quite pointless.
    As for watercooling, you could run 2 pipes from back to the front of the car, this actually has been done with amps, and it worked, cant remember how the guy hooked the radiator up tho
    Depending on the system you are running the bigger pump you will need but I think a small one will do provide you dont overclock the cpu
    Now an idea is to put watercooling on your system, run the pipes to the front then use air con to cool the rad that should work fine hehe
  6. #36
    Oct 2004
    NY
    Quote Originally Posted by viguera
    the cars cooling system is too hot to be used for pc.....
  7. #37
    Oct 2004
    NY
    eliminate all cooling problems by throwing the p4 in the garbage & going pentium m.....
  8. #38
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Quote Originally Posted by turbocad6
    I agree with that one... by the time you set up any sort of decent water cooling system you'll already have spent more. If you have the money to blow though, water cooling could be worth trying just for the coolness factor (no pun intended)
    oh, and I found someone who has his car's thermostat stuck open, and his car runs cooler than normal operating temp, only reaching operating temp if it's hot enough out.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  9. #39
    Dec 2004
    Orlando, FL
    off coarse...
    I started this thread to talk about making a cooling system similiar to a cars ac system........It has nothing to do with liquid cooling. i mentioned it as the lever that got me thinking of using a very very small refridgeration system. I know about liquid cooling and thats not what im looking for. im looking for information and ideas on how to make the compressor, condensor, ect ect.
  10. #40
    Maximum Bitrate DeltaFX's Avatar
    France
    Drop a Prometeia case in your car, and basta. Oh wait... you'll end with heat from the cpu, plus heat from the compressor (100% efficiency is a myth)....
  1. FAQ: Cooling Your System
    By Bugbyte in forum The FAQ Emporium
    Last Post: 10-03-2005, 05:09 PM
  2. Water cooling proposal?
    By Vchat20 in forum General Hardware Discussion
    Last Post: 07-02-2005, 04:54 PM
  3. cooling control panel
    By Sillydipstixs18 in forum LCD/Display
    Last Post: 05-23-2005, 03:36 AM
  4. Idea...
    By nFiniteTuning in forum General MP3Car Discussion
    Last Post: 02-20-2005, 03:48 AM
  5. Security idea - hide the HU
    By jaeger in forum General MP3Car Discussion
    Last Post: 08-23-2004, 01:17 PM
