Originally Posted by
bigbrother82
Sillydipstixs18--
I think your idea has potential but I think you should take a different tact. If you used the r134a directly piped to your cpu you would end up having a problem with condensation on your board, (which would bad), but if you kept the set up you had, and separated a small type ac unit to blow cool air onto the tubes carrying the current liquid you have, it would cool that and then carry it to the cpu, and should work better. I'm not sure if this is what you meant originally, but i think it is plausible.
