Results 1 to 10 of 12
Thread: Building a new case for my BookPC
    Apr 2000
    Arroyo Grande, CA
    Post Building a new case for my BookPC
    With all the recent problems I've been having with my BookPC, I've decided to try and relocate the unit under my front passenger seat. To do this, I need to build a new case for the motherboard, CD-Rom and hard drive that is less than 2.5" tall. I went to the local hardware store in search of sheet aluminum that would suffice for building a new case but couldn't find any that was thick enough to work.
    Has anyone else done something like this before? Where would I be able to find materials to build this? What are normal computer cases made out of? Would I be able to find a place that might custom make a case for me?
    Thanks,
    Marlin Liew
    Variable Bitrate spud42's Avatar
    Oct 1999
    brisbane,qld,australia
    Post
    believe it or not i used a cheap aluminium square cake pan. called a lamington pan in aust. approx 2"1/2 tall and fits my gigabyte ga-5ssm mobo no prob.. has a 10 mm lip all the way around to screw a flat sheet of ali to !! room for mobo, 3"1/2 hdd no prob... even room for dc-dc c0nverter.
    Volvo V40 Phase 2 2002. T4 turbo upgrade.... currently no mp3 or carputer..... researching options
    Dec 1999
    Santa Ana, CA 92704
    Post
    I plan on building a case as well, one for a mini atx power supply, small mobo, 3.5 hard drive, 5.25 cdrom, one floppy drive, one zip drive, one agp video card on a riser card and one serial port pci card on a riser. I'm hoping that I can make something nice that will fit under my seat but am not quite sure of the material to make it out of.
    I was wondering if there would be any problem making it out of a plexiglass type of material (like some of the spiffy new clear tower cases being custom made) ? My main concerns are grounding since I'm used to installing motherboard and components in normal tower cases. Would hate to turn on my computer for the first time and fry hundreds of dollars worth of computer equipment.
    Jul 2000
    Post
    you can use the plexiglass. but it will be better to use metal sheet because the graunding issue.
    Nov 1999
    Austin, TX
    Exclamation
    I used plexiglass on my first car computer and it is hard to work with because it is hard to fasten one piece to another unless you glue it up and clamp it; and it tends to crack if you want to drill holes through it. Its flexibility is not particularly helpful either. it did look pretty cool though. for my second go around i used wood for ease of construction. Whateve you use its probably best to use or line your case with metal to block interference and it makes grounding easier.
    killadam
    Dec 1999
    Santa Ana, CA 92704
    Post
    Alrighty, this leads to my next question. I'm not really much of a electric wizard of any kind, so excuse me of my ignorance. But should I use those little motherboard risers that you use in tower cases? I always assumed it was extremely bad to have your motherboard or any component touching metal. Thanks for the advice guys.
    Jul 1999
    West palm Beach , Fl, USA
    Post
    I used plexiglass on mine and use L-brackets to connect pieces. Its very easy to drill if you get decent plexiglass from a hardware store.
    Feb 2000
    hoppers crossing, victoria, australia
    Post
    i made a case for another project out of a old desktop puter cover
    nice solid steel
    might be worth a try
    cheers pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Jun 2000
    san jose, ca
    Post
    blkdragon6, where did you get an agp riser?
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Smile
    killadam: I used plexiglass to make my case. It is very easy to drill if you have a set of sharp bits and use minimal pressure. I didn't crack anything. For fastening, I used small angle irons. Works great. No noise problems either, but that could be because I am using DC-DC. By the way, who's Adam?
    blkdragon6: You will need to get little plastic standoffs. Any electronics store should be able to provide them if you tell them what you are doing. Even Radio Shack has a small kit.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
  1. Consider not building a case for Carputer
    By antimatter in forum Fabrication
    Last Post: 05-20-2004, 12:00 AM
  2. Replies: 3
    Last Post: 01-22-2003, 04:08 AM
  3. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 09:42 PM
  4. Building LCD, Case, & Mount
    By kgoode80 in forum LCD/Display
    Last Post: 06-27-2002, 01:02 PM
  5. Building a plexy case...
    By Dimitris1976 in forum General Hardware Discussion
    Last Post: 01-19-2002, 09:21 PM
