Results 1 to 10 of 14
Thread: Detecting when engine finished cranking?
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Question Detecting when engine finished cranking?
    I always wondered this. Seems that many aftermarket alarms (with autostart) can do this. What method do they use?
    Oct 2003
    Tach signal or voltage sensing...
    Feb 2005
    Quote Originally Posted by dmurray14
    Gotcha. What would happen to the tach signal once the car started? I'm assuming that there is no signal until the engine starts.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by LiquidKernel
    More of a constant versus a non constant signal. When it's cranking, there is some voltage. The system waits for it to reach a certain voltage based on the amount of cylinders in in the engine, and then waits probably a second or two to make sure that the engine is running and it can stop cranking.
    Michael
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you could do it relatively easily with the combination of the two signals from the ignition (ACC line powered when the car is on, and the other powered during cranking)
    just wait for the cranking, then wait a second or two after the cranking stops.
    also, in most cars the ACC line is not powered during cranking... therefore if you have a shutdown controller that waits until the ACC line has been active for a certain amount of time, if you crank the engine immediately when turning the car on, the SDC won't see the ACC line stay high long enough until after the cranking is done.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Feb 2005
    Thanks for the tip evandude. I am thinking of making an MCU controlled device to turn on my headlights (with an HID projector retrofit) only after crank is finished. That way I don't have to worry about having to manually turning them off while the car is cranking (otherwise they turn off and on again when cranking is done).
    Low Bitrate happpyg's Avatar
    Feb 2005
    Bunbury, Western Australia
    I used the alternator charge light signal.
    Semperon 3200+/512MB/ Seagate SATA2 120GB
    10.2" Xenarc/ Netgear USB Wireless
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    http://www.happyg.mine.nu/carpc/index.html
    Dec 2003
    Germany
    Yeah the alternator has a 3rd lil wire, usually called D wire (in German at least) and that tells you once it is turning. So that will be the way to go I think
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    In older cars: oil pressure light...
    Or voltage measuring (when running, the charging-cirquit provides a little more than the battery when idle). I don't see what the number of cylinders has to do with it though...(?)
    Or just measure the alternator output.
    Many options
    Oh and btw, before you search the 3rd wire on the alternator, that could well be the 7th wire or something, as modern alternators have multiple phase outputs and other more complex configurations...
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    the number of cylinders has to do with the tach. not sure EXACTLY how, but the information is out there if you want to search and read up on it.
    rebuilding carpc... kinda..
  1. engine wine know how its there but can't get rid of
    By michaelrj9 in forum Car Audio
    Last Post: 11-05-2005, 09:58 AM
  2. End Low voltage while cranking engine
    By bluehcc in forum Power Supplies
    Last Post: 07-26-2005, 05:03 PM
  3. Noob Questions: Turning Off Media Engine
    By FiReToY in forum Media Engine
    Last Post: 01-01-2005, 08:36 AM
  4. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  5. Replies: 4
    Last Post: 06-29-2004, 09:20 PM
