Results 1 to 5 of 5
Thread: USB cable needs some kind of locking thing
    FLAC -zip-'s Avatar
    Ontario/Canada
    Is there anything on the market that will lock the connector to the computer?
    Mine always comes loose over time, which locks up the carputer until it is jammed in again.
    Sound Stage
    Eclipse|MTX|Infinity
    Low Bitrate hakhawk's Avatar
    Apr 2005
    newborough, VIC, AUS
    superglue? honestly, i dont think there would be, as theres so many different moulded plugs out there. what usb device are you using to make it lock up the pc? i thought if it came loose, you would just loose ability to use whatever is plugged in.
    THE NEW
    : www.lowagz.co.nr ::
    THE OLD
    :: www.hakhawk.co.nr ::
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    hot glue - less permanant than some other glues
    FLAC -zip-'s Avatar
    Ontario/Canada
    Quote Originally Posted by hakhawk
    I use a dedicated USB cable for the Audigy NX, when it comes loose, it will lock up the carputer.
    hmmm guess it's hot glue then.
    Sound Stage
    Apr 2005
    ahh, ok. hey, i never thought of hot glue.
    THE NEW
    THE OLD
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. Lilliput 9pin mini-din USB VGA cable
    By Pale Rider in forum LCD/Display
    Last Post: 10-28-2005, 01:54 PM
  3. XM Direct Cable with Serial to USB adpt
    By HummDinger in forum General Hardware Discussion
    Last Post: 11-18-2004, 03:09 PM
  4. Replies: 2
    Last Post: 08-09-2004, 09:36 PM
  5. What kind LCD cable?
    By AVOGODRO in forum LCD/Display
    Last Post: 08-02-2002, 07:05 PM
