Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Making PC Hibernate when power button is pressed
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    I usually would just go to power options > advanced > and do it in there, but for some reason, I am not given the option. All that's there is 'Always show icon on the taskbar' and 'Prompt for password when computer resumes from standby'. The computer turns on fine by the power button, but doesn't turn off or do anything.
    Has anyone seen this problem before?
    Also, I've reset the CMOS to make sure everything is okay in there...
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    you have to enable hibernation under power options first before the hibernation option is in the list of power button options.
    "A conclusion is the place where you got tired of thinking."
    Dec 2003
    Edmond, Oklahoma
    Yeah, I enabled it, that's not the problem. The computer can hibernate fine when I tell it to from windows. The problem is, how do I get it to hibernate when the button is pressed? Like usually a computer will say 'When I press the power button on my computer:' but on my computer it doesn't say that at all?
    Raw Wave justintime's Avatar
    Apr 2005
    On my WinXP, it shows under:
    Power Options -> Advanced
    I have set it to Shutdown, but hibernate is an option as long as you enable it in the Hibernate tab...
    Quote Originally Posted by XxAndyxX
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Dec 2003
    Edmond, Oklahoma
    ^that's exactly what I see EXCEPT there is no power buttons box...
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    set the power settings in the bios first
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Jaz
    Jaz is offline
    Apr 2005
    are your display drivers etc installed? drivers that are not installed will cause this problem.
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    that feature may be within the setup CD of the motherboard, or sometimes if you do a update through windows it will add it as well.
    BossTone74
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Do you have a tab for APC or APCI or whatever it is.. sometimes if the power features aren't enabled in Windows, it won't show up. It'd be another tab in addition to what was shown above.
    Dec 2003
    Edmond, Oklahoma
    In the APM window I have this (I've tried this enabled and disabled):
    But in the advanced tab it still shows this:
    In the BIOS, APCI is enabled, but it doesn't show any options for when the power button is pressed.
    Video drivers are install, and I'm using Service Pack 2.
  1. Replies: 25
    Last Post: 04-27-2008, 05:40 PM
  2. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  3. ITPS reprogramming ?
    By naruto in forum Power Supplies
    Last Post: 11-26-2004, 02:19 PM
  4. I want to add a power button on my dash. Which can i use?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-25-2004, 04:17 PM
  5. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-22-2000, 12:00 AM
