see this thread
VIA 1.3ghz mobo, sp-13000...good one?
I've been ripping my hair out for the past couple hours trying to flash the bios of this board. Since there is no floppy drive connector, and I do not have a usb floppy drive, I have been trying to make a cd boot disk without any success. Does anyone have any tips or a guide that I could follow? I have a usb zip drive, as well, if that helps.
see this thread
Trying to fit a PC into an Alfa Romeo GTV. It's installed, but the buttons have fallen off since.
if you have nero, switch it to advanced mode and create a bootable cd with it. Just stick the bios file and the flash util then boot from cd. I did it myself yeasterday and it works a treat. If you havent got nero, then let me know and I will make a iso from a cd here so all you need to do is burn it and you can then flash from it.
cheers
CdR
