Results 1 to 7 of 7
Thread: More help on motherboard ID!
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Hi,
    DarquePervert was good enough to help me with my last motherboard ID, and I've since overclocked it from 833MHz to 976MHz, with only a 3deg increase in temp from 20degress! Bigass fans are the way to go.
    So, I'm wondering if you could help me identify this one
    1996 Volvo 850 T5 CD - Eventually I'll start....
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Looks like a SiS p4 motherboard. Probably crap.
    Apr 2005
    Ireland
    Just what I thought. The MSI board in the carputer is quite good, although I can't access the vcore to change it...any idea how? I speeded the FSB up from 133/32 to 150/37 and I camedown stairs to see that the CPU had gone back to 19~degreees!
    Is it an ASUS SiS?
    check out cpu-z seach on google for it, i bet it could tell you
    02' Focus zx3
    10% [//////////]~*
    Status:
    Planning
    Apr 2005
    Ireland
    Nope. came up with the mainboard window blank.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    You should try getting a better pic of any of the identifying text on the board, especially that text around the lower left hand side of the processor heat sink mounting bracket... that looks like some sort of model number, but it's a little too fuzzy for me to make out...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Apr 2005
    Ireland
    Pah, I'm going to upgrade it soon. One of those MSI boards with two processor slots and then two dual-cores and then overclock those...
  1. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  2. Which Motherboard to Choose
    By james33440 in forum General Hardware Discussion
    Last Post: 06-07-2005, 11:35 PM
  3. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  4. Motherboard Vibrating, will it be damaged??
    By syclone477 in forum Newbie
    Last Post: 05-02-2004, 12:28 AM
  5. WT: Celeron Setup for Slot A motherboard
    By EBoundEE in forum Classified Archive
    Last Post: 04-28-2004, 04:06 PM
