Results 1 to 10 of 10
Thread: Which MoBo should I get?
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    OK…I know I’m going to get ripped for this one…(Sorry for the noobie question )
    Right now I have a VIA 600 with 512 PC133 and a notebook HD 40G
    I wanna up grade, but I wanna keep my OPUS 120…
    What mobo should I get?
    I ready wanna stay away for VIA unless I go with 12K, but that a $200+ board…
    I know I could get a better board for a fraction of the price….but what should I get?
    Any recommendation…
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
    Feb 2005
    Miami, Florida. 305
    OK, narrowed my choice to a Via10K or an IBM SFF P3 800 or 1G...
    Anyone has any input
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    why are you stuck on VIA ?
    REBUILDING!!
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by Dragonknell911
    I'm trying to stay away from VIA, but I'm using/have an opus120...
    What would you use or are using....
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    I prefer the VIA MII10K (or greater) for automotive. the reason is the systems are better suited to the heat and cold better than a desktop motherboard.
    Most motherboards are rated for Operating temperatures 5°C ~ 35°C
    the Via ITX are rated for 0 ~ 50°C
    This makes a big differance in a car. I have seen my car get to 45C in the afternoon. Most PC's would fail at that temp.
    THe VIA also comes with a processor that is soldered in. other motherboards are in sockets. Sockets can fail due to dust and vibration.
    VIAs are also take less power to operate. They will play DVD's,videos, MP3s, Run your navigation. 1.2Ghz is plenty of CPU for these operations
    Playing games is not a priority for most with a carputer and the small screen is not good for gaming anyway.
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
    Feb 2005
    Miami, Florida. 305
    OK...need help Here is what I got...
    ASUS P4BGL-MX i845GL from ebay, I have not purchased a processor nor memory yet...
    assuming I went with a P4 Socket 478 (533 FSB) and 1 stick of 512 DDR
    Using a power calculator with the following: (1) stick of DDR, NoteBook HD, about 3 USB Devises, Fans, and Monitor running of power supply (like before using my VIA 600) "Recommended Minimum Power Supply is 173 Watts Peak!"
    I guess my opus 120 won't work what do you guys think
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Elsewhere
    I think you made a poor choice if your intent was to use an Opus 150w.
    How about the Wiki?
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by DarquePervert
    My plan was to use a VIA board...which I did, but performance out of a via MoBo was (mainly the board I was using 600). I guess I need to purchase an opus 150
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
    Elsewhere
    Quote Originally Posted by UM_Fan
    I don't think that will work witht he setup you're planning, either.
    Look into a Keypower 250w (no shutdown controller or batter protection, though) or a Maestro sproggy.
    There's someone else here developing a more potent car PSU as well.
    How about the Wiki?
    Feb 2005
    Miami, Florida. 305
    I think I can get by using an OPUS 150, I belive jcdillin used it on his first install...
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
  1. mobo/ Pentium III processor question
    By AUskier in forum Newbie
    Last Post: 02-11-2005, 04:39 AM
  2. Asus Micro Mobo and AMD XP-M 45W Barton
    By MatrixPC in forum General Hardware Discussion
    Last Post: 01-05-2005, 06:26 PM
  3. FS: mobo, power supply, CPU etc just look!
    By dannn in forum Classified Archive
    Last Post: 11-01-2004, 10:52 PM
  4. confused about mobo choice ...
    By thunder in forum Newbie
    Last Post: 09-07-2004, 10:52 AM
  5. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 09:24 PM
