Results 1 to 10 of 13
Thread: Quicker Getting INTO Hibernation
    Apr 2005
    I have searched and searched and all i can find are posts about getting out of hibernation quicker. I need to learn how to make it get into hibernation quicker. My carnetix shutdown controller has 2 settings 6 secs and 15 minutes. I want to keep it at 6 secs but the compter isnt getting into hibernation quick enough. I have a M10k, 512mb ram, Win XP Home
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by MikeyTampa
    Why do you want to keep it at 6 seconds. As soon as the computer goes into hibernate, the computer shuts down. So what if it has power for an extra 14.5 minutes. It isn't drawing anything. Plus, even if it were, 15 minutes of the computer completely on would do little, if anything, to your battery or car even with the ignition off.
    Michael
    Apr 2005
    Quote Originally Posted by Wiredwrx
    Michael
    See what I thought the 15 minute deal would do is set it to hibernate but not cold shutdown for 15 minutes but it just leaves it on and I am thinking it will do the same thing when it finally does shut it down it will still only give it a few seconds to shut down.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Perhaps you can explain in better detail exactly what you mean. Explain what you think happens, and what you want to happen. Try and be as specific as possible. Please add punctuation as well.
    Michael
    May 2005
    Vienna, VA
    It's only gonna be as fast as the write speed of your hard drive. Either get a faster hard drive or use less RAM. Unfortunately, there's not much to optimize in hibernation. It's too simple of a process.
    Apr 2005
    Ok heres what happened. When I first installed it it would get to hibernation quick enough and everything was fine. Every once and a while it would get caught and not get into hibernation.
    Then for some reason my hibernation file was corrupted so I had to delete it so the computer could start. Ever since then it takes a lot longer to get into hibernation. I don't know what I could do...can I reinstall hibernation? Could I have a seperate program take over that function?
    About the 15 minutes option. If the startup/shutdown controller sent a hibernation signal right away then it would be cool because it would have 14.5 minutes to get into hibernation. What 15 minutes really does is keep it on for 15 minutes after I leave the car so it's still going to send the turn off signal with only a few seconds left of the 15 minutes to be up.
    SOOOOO I was wondering if there was anyhting to speed up hibernation. I thought maybe if I stripped the things that start up then it would be quicker getting into hibernation. But only 2 programs start...RR and Touchpad for my xenarc and it still takes a while to get into Hibernation.
    FLAC SFiorito's Avatar
    May 2004
    well, they already mentioned ram and hdd. the only other option is to use Hibernate Once, Resume Many from XP Embedded (see the OS Optimization forums for more info). Basically you'd have to install and enable EWF on your system and then you would only hibernate once. when you turn the power off all you need to do is a normal shutdown.
    but from what you're saying it sounds like your hdd is the culprit. maybe you need to run chkdsk and/or defrag?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    My laptop takes a bit to hibernate to. Like everyone says,all hibernation is writing your RAM to the HD.
    Your HD is too slow for that much RAM. Either get a faster HD or less RAM.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    From what I understand is your computer take too long to hibernate and the SDC cut power off before the hibernation process complete. For example: The SDC cut off power 30 seconds after it pushed the power button, and the PC takes 45 seconds to complete the hibernation process. The result is a currupted hibernation files.
    Is there anyway you can extend the time the SDC cut off the power to let say 1 minute instead of 30 seconds?
    Reduce RAM to 256MB to see if the PC going to hibernation any faster.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Which SDC are you using?
    Michael
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. Alternative to Hibernation..
    By Jehvi in forum WinNT Based
    Last Post: 06-10-2005, 03:23 PM
  3. I'v had a thought! - Make Hibernation Better?
    By mick-uk in forum WinNT Based
    Last Post: 05-19-2005, 09:39 AM
  4. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
  5. Not coming out of Hibernation (Intermittently)
    By Jailer in forum General MP3Car Discussion
    Last Post: 10-23-2004, 10:11 PM
