If you really want Windows CE, you'll have to pay for both the developer kit and a device license from Microsoft, and they're usually expensive.
Windows CE is more properly called Windows Mobile, and there's a Mobile CE and XP versions.
Start looking here:
http://msdn.microsoft.com/embedded/default.aspx
There's a Windows Mobile CE trial version that you can download and try before you buy.
The trial version will let your device run for a limited time, usually 30 to 90 days, and you can't get around that, it's built in.
You'll need to use the development kit to build a target image for the system you're planning to run it on, and load the image onto the hard disk.
It's complicated and expensive, but certainly possible.
LinkBack URL
About LinkBacks
yes XP is very tweakable. and the OS by itself doesn't make the system boot up quickly. "real" WinCE devices like PDA's or
