This guy had a lot of stuff including distros, but he is holding the sales for now. (until he return from school or something)
NEW-Neema12 Summer Sale-NEW
There are a lot of amp kits and individual power distribution blocks I've found (searching for days) but they're all 4 GA in, and 8 GA out. Since I'm only running an epia, no dvd, 7" Xenarc, a CB, and a Scanner I ran 8GA from the battery to the interior. Opus recommended 12 so it felt like I was erring safely enough. Shouldn't touch more than 25 amps at the most.
I had picked up a 4GA-in / 8GA-out block earlier today but it looked sloppy with the smaller cables so I returned it (didn't hold the wires well anyway).
Has anyone seen a fused distribution block designed for 8 GA in, and 10-12 GA out?
99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
currently: installing (finally!)
I used a 4GA-in / 8GA-out like you tried. Just cranked the screws down so the wire wouldn't pull out. It's buried under the dash so I don't care what it looks like, it works.
Z
Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
fold the wire back onto the sheathing and clamp it all in the hole
Get a simple (and cheap) screw type fuseblock.
This one was sold for RV use, cost $10 and accepts up to 4ga in. I have wires connected to it ranging from 12 to 18 gauge. It ain't pretty, but the alternative is a bit on the pricey side, not to mention overkill.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
do you have that mounted in a case or anything so moisture or another loose conductive material laying around doesn't accidently short anything?
Check out the tsunami blocks. I'm sure they have what you're looking for.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Nope. It's mounted vertically under the hood near my my primary distribution block, no loose wires around. It didn't come with a cover, but you could hack a Radio Shack hobby box easily enough.
From my positive battery terminal I have a short run of 1/0 gauge to a Stinger block with 4/8ga outputs. A short section of 4ga then connects to the above block, and I have the other three outputs on the stinger taken up with 4ga to one amp, 8ga to a second, and 8ga to my pc/accessories.
The screw type fuse block powers my alarm, remote start, aux piezo sirens, seat heaters, trunk pop, etc. It really helped clean up my battery terminals, which were a maze of wiring.
Found this late yesterday. Seems to be more like what I'm looking for. simple, affordable, does the job. various sizes (2-way up to 12-way), and gangable if you need to add more. lexan cover with rubber seal to prevent moisture or unwanted contact. Simple connectors, just plug on some female disconnects.
for $12.95usd, sounds like just the ticket.
fonseca where did you find that auxilary fuse block and jagsnag where did you find yours ?
REBUILDING!!
