I'd say go for the 150W version, you never know when you might need the extra juice.
Hi!
I am in the process of buying my first car PC. I was going to buy the following:
http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=5225874403
adding memory up to 512Mbyte
and a Hard Disk of 80 Gbyte
Overall computer cost is 300US$
The system will be connected to a indash 7" motorized 1 DIN Touch screen VGA display (bought in China for 270US$).
Questions for help!!!
1) Power supply, is it better a opus 150W (will it fit??) or is enough opus 120W board....is it difficult to put in inside that case?
2) Overall system is it ok, will I need something against vibration of the car?
I could not find info on the web about the processor and/or board!!
Thanks a lot!!!
Tech. Infos:
- NEOLEC FlexATX Mini-Tower mit 110 Watt.
- PCCHIPS M789 Mainboard
M789CLU V1.2 motherboard is based on the CLE266/8235 chipset.
Supporting VIA C3 Samual 2 processor onboard, up to 133MHz FSB,
DDR266 with UniChrome 3D Graphic engine, it shall deliver you both performance and great value.
- VIA C3 Samual 2 CPU 2000+
- Toshiba Slim-Line IDE DVD drive 16x
- Embedded UniChrome 3D Graphics with 64 MB memory
- AUDIO: VIA VT1612A 2-channel audio Codec, AC97 2.2 specification
- LAN: VIA VT6103 10/100Mbps Fast Ethernet PHY , DSL fähig
- 4 x USB 2.0
- Connections: Floppy, Seriel, Parallel, 2 x PS2, Audio
- Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
- Full support for ACPI revision 1.0 specification
- Flex-ATX Form Factor, 230*190mm
