Results 1 to 7 of 7
Thread: New USB FM Radio
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    Exclamation New USB FM Radio
    Has anybody seen this yet? Any ideas or comments? Maybe a good solution for FM capability on our carPC's.
    Link to Engadget article
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    2000 Mitsubishi Eclipse GT
    - V6 216hp
    - KYB-AGX adjustable struts
    - Konei Alloy 17" rims + Pirelli P-Zero's
    - AEM slotted brakes
    - AEM CAI
    sim
    sim is offline
    Low Bitrate sim's Avatar
    Jan 2005
    Gloucerstershire UK
    Does'nt seem to be any provision for an external antenna,without one I can't see how you would get reception in a car.
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
    Feb 2005
    New York
    I would be curious to see how the antenna is set up. Just to see if you could hack together a car antenna connection.
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    - V6 216hp
    - AEM CAI
    Newbie contri's Avatar
    Jul 2003
    antenna
    I bought an Avermedia USB FM radio for my setup, http://www.pocket-lint.co.uk/review.php?reviewId=502.
    A friend and I found out that it got the ground signal, needed for Left and Right sound channels from the USB, and used the then free pin in the headphones as antenna. So, the headphone cable had another cable, quite long, which worked as anttena. Maybe this one does the same trick.
    We didn't try it in a car, though. Software control with Fairy Radio wasn't as good as with the mythical D-link one.
    Elsewhere
    Quote Originally Posted by contri
    The DLink isn't mythical. It's no longer manufactured.
    How about the Wiki?
    Feb 2005
    AFAIK Avermedia USB FM radio uses the ground pin of the headphones jack as ground signal from the antenna, and the left (don't remember now, maybe right) channel pin to real antenna signal.
    I'm thinking about soldering a car antenna adaptor to those pins and connect to it to the factory antenna of the car.
    As I can see in specs of the car, the impedance of my antenna is 75 Ohms. Can anybody tell me if i'm going to burn my car if I do this?
    Jul 2003
    Sorry for the 'mythical', DarquePervert. It seems that 'mighty' was more accurate.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. USB FM modulator.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 10-01-2004, 03:24 AM
  3. FM CF card
    By Twopoint in forum Car Audio
    Last Post: 07-18-2004, 04:44 AM
  4. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
  5. What are you guys using for FM radio in your carputers ?
    By Nokia6600 in forum General Hardware Discussion
    Last Post: 03-03-2004, 12:35 AM
