Results 1 to 10 of 12
Thread: Plexi case and faraday cage
    Jul 2005
    Calgary
    Plexiglass case seems to be the cheapest, easiest way to build a custom case. But with all the antennas and such, don't want to be leaking alot of EMI around the interior. So. Faraday cage it is. thinking of wrapping small gauge chicken wire, like what you use to keep the rabbits from eating your plants, around the case either internally or externally.
    I guess I could squash the chicken wire between 2 sheets of thin plexi and seal together with some clear acrylic glue.. OR a layer of tinfoil between the plexi layers. Question: would this even be beneficial? ie would it block emi? I don't have any frequency counters to check.
    case location is under a seat, so looks aren't that big a deal.
    besides helping with the question above, 2nd paragraph, here's more info on faraday cages if you're just searching...
    http://en.wikipedia.org/wiki/Faraday_cage
    99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
    97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
    currently: installing (finally!)
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    ???? why are you so worried about EMI from your PC?
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    I was worried about it so I built mine out of 1.2mm aluminium. However, I think the worst case of EMI in the car will be the Car PC... So it won't make any difference IMHO. Plus side is the aluminium is a great heatsink!
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Quote Originally Posted by Scouse Monkey
    I agree. What could possibly be damaged?
    (Continues to wear aluminum foil helmet...)
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Mar 2004
    Bristol
    I worry about EMI around where I sleep. But in my car i am surrounded by all kinds of ****. are you worried about getting prostate cancer from it being uder your seat? If you are put a 2mm thick sheet of alloy between the PC and you or wear foil underpants!
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Where can I get those underpants? It would match my hat. You know the goverment can read my mind without it.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Poet Laureate rustyboxx's Avatar
    Feb 2005
    The Côte d'Azur of England - Hot totty central
    I always find this a useful carpc enhancement
    Only true postwhores remember everything they post
    REP CLUB IS DEAD
    LONG LIVE REP CLUB
    Feb 2001
    Quote Originally Posted by rustyboxx
    My hat is better than that. It looks like they just rolled some foil around his head.
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
    Mar 2004
    Bristol
    I cant see the pic
