Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 91
Thread: Problems making network cable
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Unhappy Problems making network cable
    I got myself some 100m of network cable to run from my living room to my bedroom. The distance is like 6 meters. But I can't seem to make the cable correctly or something. Like I make the cable, plug it into my 5 port hub, and windows says aquiring adress, and then it says problem aquiring IP adress. My router is set up to use DHCP, so I don't see why it gets that problem.
    Guide I'm using
    Other guide I used
    Neither of these guides work...
    Anyone know the problem?
    BTW: I tried "ipconfig /renew", and it times out
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    You crimping hard enough and making sure the ends reach all the way to the end of the connector. Cuz if you have one of the cheaper crimping tools it wants to pust pressure on 1 side so like the last 1-2 wires on the other side dont go thru the insul and dont make contact. i would Multi-meter it to make sure u are good at each end of the connectors
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by 84RegalRider
    Yeh, I'm using a cheap crimp tool... how'd you know?
    I'll test it with the multimeter then. BTW: Which wiring diagram is correct
    I think both are correct since its just staight through. I could've done it randomly, and repeted the same random at the other end, it should work.. right?
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    It's straight-through, but I wouldn't just wire it randomly. You want each signal and associated ground to be on the same twisted pair, otherwise the twisted pair is useless and you'll get out-of-spec noise and interference (which could introduce enough error to cause your problem, but you didn't wire randomly, right?)
    Nov 2004
    San Diego
    If you got a reg network cable you should be able to see the colors of it and that will tell you what order to go in.
    Hehe sorry i dont know off hand but its been 2 years since i made cables.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Jul 2004
    Berkeley, CA
    I did follow the diagram... both infact
    I metered the first and last pins, and they seemed good. Couldn't get to the middle one because I don't have 4 hands. My multimeter cables are too thick to touch the contacts
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    You did try this with regular (working order) network cable right?
    Your comment about the router makes me wonder if this it the first time your trying to run this computer/router combination (in which case it isnt the best time to try your luck at making network cable... even tho its easy)...troubleshoot each part independently...
    Roy
    2005 Range Rover 4.4
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    I use the B style. Pin 1 white/orange orange/white white/green blue/white white/blue green/white white/brown brown/white pin 8. On both ends. Thats a straight-through cable. If you make a A style to B style you get a crossover. I foget the A Style I think orange and blue get switched. yah thats right orange and blue.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by RoyN
    Yeh, the laptop works with a normal cable. The hub is a 5 port, with only 1 of the ports populated. So I just plugged the new cable into the next port. The hub does work.
    Quote Originally Posted by pRoFiT
    I used only one style. So same on both ends
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    I use this pin-out to make cables. I also bought a better crimp tool, the first one I had was plastic and did not crimp worth a crap.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  1. need help making vga cable with only 6 wires
    By David7586 in forum LCD/Display
    Last Post: 09-11-2005, 06:12 AM
  2. Messed up VGA/USB cable
    By carfreak01 in forum LCD/Display
    Last Post: 08-19-2005, 06:08 PM
  3. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 07:24 PM
  4. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 12:25 AM
  5. 1:1 Hirose Cable Group Buy!
    By claylong in forum Classified Archive
    Last Post: 08-31-2002, 02:55 PM
