Results 1 to 4 of 4
Thread: Slim DVD drive not detecing
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Slim DVD drive not detecting
    I spent this weekend installing my subs and a new amp and I also wanted to fix my DVD playback. After watching a DVD for about 45 mins it would crash. Turns out it was Power DVD so i installed WinDVD and that fixed the problem.
    However, there's still one problem. When my DVD drive detects and shows up in My Computer, it works beautifully. I ran a couple movies from begining to end w/ no problems. However, when it doesn't detect, which is often, obviously nothing works. I've been spending some time trouble shooting, but can't get to the bottom of it. #1 - When the computer boots w/ it plugged in, it almost never detects. (when it reboots after hibernate, it still doesn't detect it even it was detected before hibernate.) #2 - WHen i plug it in after it boots, it almost always detects. #3 - When it was plugged in at boot and i unplug it, it almost always takes 2 tries of unplugging it and plugging it back in for it to work. On the times where it doesn't detect, Device Manager refreshes itself once every second until i unplug it, then the next time i plug it in it works. I tried using hibernate trigger and dev con to disable it and renable it on hibernate, but that didn't help at all.
    Is there anything i can do from the command line on start up to make it work, using devcon or something?
    I'm using an EPIA M10000 motherboard. I'm not sure of the brand of DVD drive, but it is a slim dvd drive plugged into a USB converter. It shows up as QSI DVD-ROM SDR-083 in device manager. THe converter is plugged directly into the motherboard.
    Thanks for any suggestions!
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    FLAC -zip-'s Avatar
    Ontario/Canada
    If you find a solution let me know! There seems to be a lot of installs with EPIA boards with this problem, mine included
    USB Hub not working after coming out of hibernation
    Almost Done My CarPC, have one issue unresolved
    Problems with Usb to IDE Adapter
    Sound Stage
    Eclipse|MTX|Infinity
    Jun 2004
    Virginia
    yeah, i read some of those while searching for a solution. Seems to be a VIA issue. i don't understand why unplugging and plugging it in works but devcon disable and enable doesn't work.
    Jun 2004
    Virginia
    Does a PCI USB card get around the problems of the VIA USB chipset or is that just a pipedream.
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 12:50 PM
  2. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 06:37 PM
  3. FS: 7" Lilliput w/ TS, iMac slim slot load DVD
    By sohr in forum Classified Archive
    Last Post: 08-15-2004, 11:35 PM
  4. Extending USB 10' + for slim DVD drive.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-08-2004, 01:14 AM
  5. Panasonic UJ-815 Slim Slot Multi DVD Drive $249.00
    By dfwdepot in forum Classified Archive
    Last Post: 02-12-2004, 11:53 PM
