Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Carputer won't go past post - USB issue
    Dec 2004
    QLD Australia
    Unhappy Carputer won't go past post - USB issue
    This ones got me baffled. Did a search and found a few similar problems, but moreso related to external HDs.
    I've just got GPS going, and have now put in an active USB extension cable to put the receiver in the front (carputer in boot). It worked fine for about 3 days, only problem being it wouldn't re-detect the cable/hub and receiver after boot/hibernation. All I had to do was unplug, replug and away she went.
    Today I got around to setting up devcon, but the troubles have got alot worse. Now it won't boot. It gets to the post screen (big blue HP logo), and just freezes. Same deal wether I reboot or resume from hibernate. It's got me stuffed because it was working perfectly for a few days beforehand, and only started to play up today. I disabled USB legacy support (although it boots fine with just my usb mouse), but to no luck. The computer is a cruddy ole HP Pavillion 8513 (http://h10025.www1.hp.com/ewfrf/wc/g...&lc=en#N10066).
    Any ideas guys? Cheers.
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    One of my laptops refuses to boot/post until I unplug the USB hub connected. Tried with a different USB hub and it worked fine.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    try powering the extender.
    Jun 2004
    The North, Manchester
    got a USB CD ROM?? Mine wont boot with the IDE -> USB plugged in.
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i had the same problem. i went into my bios and changed the boot settings. one of the setting was boot other devices? it was on yes. when i switched it to NO and restarted with my usb laptop hdd in it it worked fine!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    My Epia M10000 won't boot with a Sandisk 256mb USB flash drive plugged in. Unplug it and it boots fine.
    Want to:
    Dec 2004
    QLD Australia
    Quote Originally Posted by JPuma
    She's unpowered
    Quote Originally Posted by OriginalNick2
    Nah, just an IDE CD ROM
    Quote Originally Posted by EsKALad
    Boot from removable devices used to be first in BIOS boot from list, but is now last. I'll try removing it alltogether. Still just seems wierd that it all of a sudden stopped working, with no hardware or bios changes. Cheers guys for the suggestions so far.
    Jan 2005
    I have that problem on my desktop but the only device it does it with is my usb connection on my v400 phone if i unplug it it booth right up
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    ha, i've had it happen with a brand new machine and a usb wifi nic
    PC Components:
    My work log
    FLAC -zip-'s Avatar
    Ontario/Canada
    Add me to the list
    USB CD Rom if plugged in will not boot, if plugged in after Windows boots, all is fine.
    Same with USB memory stick for storage.
    I spent some time on the VIA forums reseaching this and it is a definite issue with VIA boards. Apparently there will be a SP3 from Microsoft that will help.
    Unless I get the resolved, there is no point in having a slot load DVD in my setup
    Sound Stage
    Eclipse|MTX|Infinity
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. 2005 Pontiac GTO - wake's Carputer Attempt
    By wake in forum Worklogs
    Last Post: 11-24-2005, 04:00 PM
  3. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  4. Replies: 4
    Last Post: 04-19-2005, 09:08 PM
  5. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
