great thanks for posting that. PM me your name if your on AIM or YAHOO
Here is the results of BIOS can on my Insight.
Mine is able to resume from Hibernate & suspend?
USB stays live when power down.
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
When you get a chance can you verify that Suspend (Suspend to RAM) works consistantly. Try it like 5 times.Originally Posted by Tuned Vitesse
The problem we all have noticed was that when board goes into standby (STR), that it goes into standby fine but sometimes it has a problem coming out of standby. The fans turn back on and it sounds like the computer boots up but it just sits there on a blank screen. I guess if you never used standby you would be fine.
Thanks for making an apearance and posting your info. Susbscribe to this thread becasue later on we might need you to test something or tell us your version. Thanks again![]()
@Tuned Vitesse: what PSU you are using to power the system?
Probably since its inside the house a regular AC powersupply.Originally Posted by tj!2k4
When i took mine in the house i bought a bran new 350w power supply and the first time it resumed but gave a pc beep and each time after that it displayed the symptoms described
No it suspends and resumes perfectly, the fans stop but USB remains active, but I have it set to resume of USB mouse/keypress so that may explain that, also it does a 2 sec. bleep on power-up. Every now and then it hangs or BSOD on shut down but its something to do with BT and Phoco that I think.
Its running off a regular P4-400W 240v ATX PSU.
Only had a car to put it in for 3 weeks as I wrote my other off in June and I've been slackingso its not fitted yet. But I will be using my newly purchased SP13000 in car when it appears
well me and jcdillin are out of commission for a while. worst case scenero they will load the original bios back on there for me. Best case scenereo they fix all the problems with a new bios. The board should arrive there today. I will contact them next week with with a status update.
@Tuned
If you have a free moment would mind taking some photos of your Bios setup so tj!2k4 can try to duplicate them to see if it resolves the issue. It may be a workaround.
I tried making it resume on USB and keeping the USB active, both would never make the resume consistant.
肚子笑痛了
S60 Install
