Results 1 to 3 of 3
Thread: Putting USB/Firewire jacks up front
    Aug 2004
    I have my PC mounted in my trunk. I'm using an EPIA Mii board, my PC case has front-mounted USB, Firewire, and line-in and mic-in jacks, and my motherboard has headers for all that. I also have the wires that connect all that to the case jacks.
    What I'm wondering is, could I get away with removing the whole connector board from my case and extending those wires up to the dash? I could mount the whole panel somewhere, probably in the center console/armrest, easily enough. But if I use, say, cat5 cable, would USB2 and Firewire work over that? I know the audio would probably be fine.
    Alternatively, maybe I should just use panel-mount connectors for this stuff, instead of salvaging what is inside the case? Thanks for any suggestions.
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    Works for for usb.
    I used a 1mtr male/female extension, cut it in half, and joined a lenght of cat5 network cable into it, runs my dvd-rom.
    Then I got a 1mtr usb a/b (printer style) cable, did the same with cat5 and plugged that into a hub up front to give me 4 sockets for spare mouse and card reader etc.
    audio and video can pick up noise on cat 5 on long runs.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    I have front mounted USB jacks.. much like the front of PC cases.. that way I can plug in flash drives or other USB periphrials when needed..
    you might want to wrap the cat5 in tin foil for shielding I just used an old brtoken keyboard cord for the extension.. spliced in of course.. but already ahs shielding
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
  1. FAQ: Boot directly into your front end
    By d_sellers1 in forum The FAQ Emporium
    Last Post: 03-06-2010, 04:22 AM
  2. FAQ: Front Ends & Support Software for Car PC's
    By Bugbyte in forum The FAQ Emporium
    Last Post: 09-06-2007, 01:02 AM
  3. sound from front channel only on audigy 2 nx
    By Carter in forum General Hardware Discussion
    Last Post: 09-26-2005, 05:23 AM
  4. Looking for Front End
    By Wiredwrx in forum Software & Software Development
    Last Post: 05-25-2005, 04:00 PM
  5. So many Front Ends now, we need a Front End to load the Front Ends.
    By LESLIEx317537 in forum Software & Software Development
    Last Post: 04-09-2004, 04:53 AM
