Help with Pyle 6.8" LCD
I purchased this LCD on eBay a few months ago and I have finally reached the point where I can test it out, but can not get it to work. I have supplied and tested the power (bannana plugs in the rear of the case hooked to 12v & ground), given it video and nothing! No power light... Nada! I contacted the seller and he only offers a 7 day return policy, which I respect, but none the less it does not work. He said in is under factory warranty. But heres the thing! I lost the instruction manual and the warranty card. And http://www.pyleaudio.com is not much help. Does anyone know how to fix the problem or have a spare warranty card available? It is one of the last (and expensive) things I need to get my car computer up and running.
TIA Maveric
Double check how you wired up tthe LCD. If you're using one of the extra power plugs off your PSU, the yellow wire is +12v and both black wires are ground.
On my LCD, there was a "power" lead as well as an "accessory" lead. They both had to have power in order for the LCD to turn on.
I have checked that many times. And there is only the power and ground wires.
1.) I am shocked that your pyle LCD does not have an acc. line (being that the LCD was specifically designed for in car use)...
2.) Try to connect the LCD to your car, the powersupply from the CPU may not be providing enuff power
There is no Acc line, just 12v and ground, and two inputs for video and audio. I connected it to the cars power and still nothing! I have emailed Pyle and no response in 3 days. I have looked all over for the warranty card and can't find it. Any suggestions?
