did ya spill soda on the buttons... they may be sticking
other than the current problem, how do you like the 8" ??
I have a Lilliput 8" monitor. It will be working great then it will start going though all of the video settings( S-Video, Video 1, Video 2) and just today it started going though the video setting, but now the letters are inverted. And it keeps auto adjusting. It dosen't do it all the time just every now and then.
Has anyone had this problem or know why it would do this?
Thanx!!!
Make sure all the cables are tight. You might have a weak/jumbled signal going to the unit.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
To answer Don 944 LA, no I didn't spill anything on it and I love the 8".
I think judoGTI may be right, the connecters are ****ty and I may be getting a jumbled signal.
Thanx!!!
I messed with the connecters and it stopped going though the video settings...for now. But it's still doing the auto adjust all by it's self. I don't under stand why, unless the connecters need to be replaced.
well i had the same problem... if you check your video connector cable.. you see that there r some defects on it. there is one problem that couses sucht appearence. the second couse r the buttons.. liliput is not the best one to make buttons and they use a strange way to take thouse button to fit on design. i would recommend you to retourn that one , or , if you wanna risk your self, open it and verify each button and connection, like all cables inside and the video cable connector on mainboard. that all..
