Results 1 to 2 of 2
Thread: VoomPC ( ampie) No power on
    Oct 2005
    Hello
    I just finish my carputer with the voompc case
    When i turning on the ignition of my car the pc does not powering on.
    When i unscrew the cover of the case then it is starting. Also when i have the pc out of the case is working...
    It seams to be that it is pc is shorted when it is closed in the case so there is a problem with the case. Does anyone knows how to fix that problem?
    Thank you in advanced,
    Antonis
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I had a problem at the hard drive (power) connector, I had to orient it so the connector was at the back of the case. When I put the cover on, it pushed that connector just enough to where it would not power up the HD.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
