Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Off-roading with a CarPC
    Aug 2005
    Plano/College Station, TX
    I've done some searching with regards to hard drive shock absorption and such. All I've really found is that mounting the drive vertically is the right thing to do. I guess this keeps the disks from hitting eachother on bumps? Would this set-up be enough to keep it going while doing some mild-medium off-roading? (Trails, mudpits, etc) Or should I just turn off the PC while I'm off-roading? I've seen a few different shock-absorbing methods, but no real confirmation as to whether they work well or not. Anyone have something they're using that they feel is really good?
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by Gearhead61
    Mounting vertically is used to fight head-slapping. The head is to a harddrive what a needle is to a record player. A head-slap occurs when a shock causes the head to strike the disk. This can cause damage to that area of the disk, or worse. Debris from the impact can gouge concentric rings all over the platter.
    Now, mounting vertically has been discussed here for years. It's effectiveness can and has been debated. I think it is more of a superstition than anything else. Some people have mounted their drives vertically and haven't had problems. Therefore, they attribute the success to their mounting job. See this thread.
    Probably not. Not anymore than mounting it flat (horizontally). Turning the PC off is a good idea, as most drives "park" their heads. How about using a small P-O-S drive for a while and take it off roading with you. Give it your worst and see how it fairs.
    I've seen a few different shock-absorbing methods...
    Again, look at the thread I referred you to. Shock-absorbing can actually be counter-productive. I don't do it and I don't mount vertically. I haven't lost any data on my carputer. This could just be the luck of the draw.
    Aug 2005
    Thanks! I found that thread earlier but got bored (being an engineer and all too familiar with gravity) with the discussion of the force of gravity, which seemed to go on for too long, so I quit reading. I did come away with the concept that some shock absorbers can create harmonic motions with the drive and cause all kinds of trouble. I wasn't sure if there were any that didn't. =P Your idea of just using a POS HD at first through my first few off-roading trips is a good one. I think I've got a spare hard disk laying around somewhere. That way I'll know what it can take, along with the rest of the computer system.
    Oct 2004
    NY
    if I was building a pc for off road use I would defanately start off with a panasonic toughbook..... the whole thing is built to take much more shock & vibration than anything else as far as pc's are concerned... not just the hard drive either.... which is incased in a gel suspention...
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I'll wager that you are surprised at the resiliance of even a POS hard drive.
    If you're really worried about this, get a solid state hard drive and use nLite to slim down the OS.
    Want to:
    Registered User
    Oct 2005
    OKC
    i'm not sure if this is a good idea or bad idea. but this just popped up my head. you should try using medium soft springs and put it in each corner of your hard drive. so everytime your car bounces, your HD wouldn't bounce as much. of course it WILL bounce but it wouldn't strongly bounce as much. then add a small cushion on the bottom so it won't hit from your HD to your board. i know it might look funny but at least it could help maybe? give some feedback if it's good or bad idea.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    i dont think it is much of a good idea.... maybe a hard gel would be useful, as it would dampen vibration, kilsomeimpact, but noy cause negative harminc effect i think....
    Probably still best to bolt it strongly to the car....less vibration, somebumps but no flopping around
    Roy
    2005 Range Rover 4.4
    Jul 2004
    All over the world
    Quote Originally Posted by trd-4runner
    I think that is a bad idea. Again, read the countless forums that have covered this. If you have the drive "floating" like that, then the vibrations can cause a sort of harmonic movement that will shake the drive with greater momentum than the original vibration would have caused. Also, using a cushion (especially foam) can be terrible as heat will kill a drive faster than vibrations. Almost everything you hear about harddrive mounting is just speculated. So, you might as well go with the straightforward way: Just mount the damn thing.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    I took mine on the crazy back roads of montana, (by accident) these were super bumpy, I had no issues. I was amazed that Igudance had a road about 8 feet wide marked on it's map.. I would have been VERY lost if my carPC had crapped out on me.
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    One possibility is to salvage the isolation mounts out of a dead car CD player or changer, and use them to mount the hard drive. Judging by the ones that failed on a discman, they are filled with some liquid (silicone oil?) that provides damping. If you want to be anal, match the weight of the hard drive to the weight of the CD mechanism, and you should end up with an optimally damped and suspended system.
    It might help to run a really big RAM cache or something, and set the drive to go to sleep after a short period of inactivity. If you can get the player to buffer 100 megs into memory, that could let you run an hour or more without having to access the hard drive.
  1. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  2. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  3. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 09:56 PM
  4. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
