Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Stopping current flowing a particular way?
    Oct 2005
    Auckland, New Zealand
    Exclamation Stopping current flowing a particular way?
    What is the electrical component that stops current flowing a particular way? I read that I might risk blowing up the car computers if the current into the inverter goes back the wrong way which it shouldnt. What component will stop it flowing back but will still let it flow the right way? Hope this makes sense.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    a diode is what you are talking about. You shouldn't have any problems with a reasonable quality inverter. They should have protection inbuilt to cope with this.
    Oct 2005
    Hey Thanks,
    I thought that was what it was. Im having trouble trying to find one that meets the 140W or so and 12V. Does it matter if the specs for the diode are way over. Like 400V? And does it matter if it is a rectifier or zener? Dont really understand all this.
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Really shouldn't be necessary, unless you are using some industrial inverter or something.
    Carputer status: [-*---------]
    Im thinking laptop...
    Oct 2005
    Just using an old UPS that i found, will connect the battery terminals that originally connected to the battery to the car battery and with 240V output to power the computer. Are you sure that nothing can go wrong if connecting the 12V line into the soon to be converted UPS?
    Oct 2005
    What type of diode would I require?
    ddn
    ddn is offline
    Dec 2004
    Which way does current flow? Positive to negative, or negative to positive?
    Oct 2005
    Im not sure, i know a little about electronics but not much.
    1998 Honda Accord LEV
    [-|-------------] Planning Stage
    www.kiwiwebsite.com
    forum.studiofenix.com
    Oct 2005
    I dont see any problem, just dont want to blow up the cars internal computer. If I hook the 12V line into the UPS which takes 12v battery this should be fine right? I dont see how it can mess the onboard computer up.
    www.kiwiwebsite.com
    Low Bitrate Enak's Avatar
    May 2004
    Hertfordshire, UK
    The UPS is designed to charge the battery... but should be fine if you don't plug it into the mains.
    The worst you will do is burn out the UPS.
  1. Current through a relay between two batteries
    By RFMan in forum Power Supplies
    Last Post: 07-25-2005, 03:13 PM
  2. 0.02 amp current draw?
    By Zebelkhan in forum Power Supplies
    Last Post: 06-13-2005, 09:13 PM
  3. Limit inrush current
    By pke in forum Power Supplies
    Last Post: 07-07-2004, 03:41 PM
  4. Suggestions for current for a USB relay controller...
    By Zac in forum General Hardware Discussion
    Last Post: 05-28-2004, 12:52 AM
  5. Using a deep cycle battery?
    By nullity in forum Power Supplies
    Last Post: 02-08-2004, 08:42 PM
