Results 1 to 6 of 6
Thread: looking to spend $2000 on a car PC
    Constant Bitrate sr_ryan1's Avatar
    Feb 2004
    Tifton, Georgia
    i need somthing that is small, somthing say around 5"x10"x1", does not use much power, powerful video play back, boots fast,, and for the screen i would like a 10.4" touch screen with 800x600 res, 500 nits bright, so what kind of options do i have using these specs?
    thanks
    01 blazer, LS1 engine, TR 220/220 cam, vig 3200 stall, 5.3 stage 1.5 ported heads, titanium retainers, APR harden push rods, dual X magnaflow 2.5's
    Interior: AutoMeter ultra lite's, panasonic cq8100u, kicker 8" L7's, kenwood 800 amp, PS/2,
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    since the motherboard (mini-itx) is 17cm(x) x 17cm(y) (6.7 in x 6.7 in), I would say you are off to a bad start.... now if you can go to 7"(x) x 10"(y) x 4"(z), the Travla c156 might work.....or is it the 136.... I forget.....
    y z
    \|_x
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Sep 2005
    Victoria, BC
    You're gonna need to get a nano-ITX board for something that small.
    They're 4.7" square
    Even still
    I really doubt you're gonna be able to cram everything you need in an area that small. Why does it have to be that size?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    The 5" x 10" is easy, as Splinter says a nano itx will get you that. Or a 3.5" biscuit PC (6"x4"). I'm running a PCM-9373 that has everything needed on board, and could even take a compact flash hard drive if you want to go small on that too.
    I think the tricky thing is going to be the 1" requirement. The height of heatsink/fan on many boards will break this requirement. Perhaps thermally coupling the cpu directly to a substantial ally case might work here?
    Elsewhere
    Quote Originally Posted by sr_ryan1
    thanks
    P4 mobile setup with a 10.4" touchscreen. don't know if there's a 500nit one out there. IT might be pushing your size requirements, but some creative thinking should get what you need. I think you could squeeze that into a $2000 budget.
    Check out the Pentium M motherboards in the mp3car.com store, too. They are miniITX form factor which is the smallest you can get with a P4 right now.
    How about the Wiki?
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by DarquePervert
    Not true. You can get a lot smaller than mini-itx with Pentium M. Here are 2 Pentium M motherboards that are 146mmx105mm (5.7"x4").
    http://www.advantech.com/products/Mo...E0J8&BU=&PD=EC
    http://www.advantech.com/products/Mo...QMPI&BU=&PD=EC
  1. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 08:13 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. Replies: 15
    Last Post: 02-15-2006, 12:50 AM
  4. Ordered my car PC system...
    By Merzbow in forum Newbie
    Last Post: 09-26-2005, 11:54 PM
  5. Car PC and LCD searching
    By ascarytiger in forum LCD/Display
    Last Post: 12-01-2004, 07:12 PM
