It looks like something is trying to ground through the amps housing that shouldn't be. Check your wiring, go over everything with a multimeter.
I have a 93' Altima, it came with two factory amps (one for the front speakers and tweeters, the other amp for the rear speakers) As far as I know, these amps are using the housing for ground.
I am trying to use the Audigy external USB sound card and my laptop to play music. The issue I have is; I don't have sound coming out to all the speakers. BUT... if I dismount the rear amp, I get sound at the front (tweeters and front speakers). Same thing, if I dismount the front amp and leave the rear mounted, I get sound from the rear speakers. Also, if I dismount both amps, I have no sound.
NOTE: What I mean by dismount is; I leave the wires connected but not ground the amp's housing.
So far, I have tried to play with the sound card's settings like, turn on/ off the CMSS, changing the speaker setup, turn on/off surround sound... It didn't help at all.
Do you guys know what this problem might be?
ah, I figured out last night. It just a simple mistake. I forgot to wire the Amp signal.
