Results 1 to 3 of 3
Thread: atx pin 9
    Constant Bitrate bulgogi777's Avatar
    Jun 2004
    NW FL
    atx pin 9
    Hey everyone, got a question hopefully someone can help me out with. I have an vfd accessory that I'd like to power in the front of my car. It has a 3-pin power connector that draws power from the atx cable of the mobo. It uses the three pins showed in the attached image.
    pin 6 is +5V
    pin 7 is Ground
    pin 9 - I've seen this described as +5V VSB Standby Voltage and as a +5V pwr check
    Basically I'm not sure about what to feed the device for the pin 9... because I don't want to splice and extend the atx adapter that comes with the device all the way to the front. Can I simply feed it another +5V?
    90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
    My Install
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Standby voltage is always on as long as the PSU is plugged in (which makes it a power check, I suppose.) Giving it regular ol' 5V should be fine, unless there's some settings that get cleared if you remove power or something. Basically, it will act as if you unpluged the computer rather than just powering down.
    Jun 2004
    NW FL
    cool, thanx~!
    My Install
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. ATX Pin problem
    By BiohazrD in forum Power Supplies
    Last Post: 05-18-2005, 10:05 PM
  3. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  4. OPUS 150 do I really Need the 4 pin atx cable
    By cl6four3 in forum Power Supplies
    Last Post: 05-08-2005, 08:08 PM
  5. AT and ATX pin assignments
    By drew in forum General Hardware Discussion
    Last Post: 11-22-1999, 09:47 PM
