Results 11 to 20 of 30
Thread: Crashes/shuts down on installing Windows!
  1. #11
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    Huh? I never said that, or if I did it was a mistake cos I haven't got any non-standard cables in there
  2. #12
    Jun 2005
    Didn't read the whole thread, just about to eat, but have you checked the temp in the BIOS?
  3. #13
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    No your right, my mistake... what page was I on ?
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  4. #14
    Oct 2005
    Bedford, UK
    doof, I don't have temperature readings in my bios, only voltages and fan speeds. It's a Via M10000 mobo
  5. #15
    Jun 2004
    NH
    you def. should have temp readings... I have the same board...
    Your bios uptodate ?
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  6. #16
    Oct 2005
    Bedford, UK
    maybe not then, is it in the pc health bit?
  7. #17
    Oct 2005
    Bedford, UK
    Just checked and my BIOS says it's revision 1.16 which is the latest one on the VIA website. Where are the temp readings in your BIOS?
    I just noticed in your signature that you have an MII mobo. Is that an out of date sig or do you actually have that, cos it's different to the M10000 that I have
  8. #18
    Oct 2005
    Bedford, UK
    It's just done it again. Windows 98 crashed (big suprise) and when I pressed ctrl alt del it died again!
    Could it be the ram? I'm running out of ideas
    *EDIT* Ok here is an idea. I just altered a setting in the bios which was the one about what to do if the power fails (stay off, switch on etc). I changed it to switch on and now when it shuts itself, if I unplug it and then plug it back in, it turns on. Does this mean it is a power failing issue and if so should I replace the mains adapter or psu?
  9. #19
    Oct 2005
    Bedford, UK
    Becoming a total post whore now but I wanted to update you and bump this at the same time.
    Last night I left the cmos battery out and unplugged the mains to get a nice reset on the bios. After setting the time and putting the CD-ROM as first boot device I tried again installing XP (from a freshly burned CD). Thus far it seems ok, didn't reboot during the file copying like normal and had begun the process of installing when I left the house today. I will update this post (not post another one!) when I get home and see whats gone on.
    Update: I got home and it was installed and still on! Went to the Via website to get updated drivers and before I'd even hit the home page, bang. It went again!
  10. #20
    May 2005
    Derbyshire, UK
    Good luck Tim
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 06:09 PM
  3. epia M 10000 AND WINDOWS XP PRO
    By Dluvr22 in forum Software & Software Development
    Last Post: 10-18-2005, 09:04 AM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. windows 2000, xp and EPIA 800
    By samc in forum General Hardware Discussion
    Last Post: 08-24-2003, 09:41 PM
