I'll probably have to crack open the hub either way, it has a really small barrel jack, so I would probably just wire my own connector. I think I will try the modified connector to see if it works, but if it does indeed limit the amps through the hub, would it be worth it to just add two jumpers to make it appear that the 5v is comming from the barrel jack, when in actuality its comming from the usb wire?
LinkBack URL
About LinkBacks
