Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Cold problems
    Low Bitrate cyrix^'s Avatar
    Feb 2005
    Denmark
    Cold problems
    Hey guys..
    Is getting close to winter, and we have got the first days with minus 0C here.
    I am starting to having boot problems when is getting below the freezing point. I just won't boot. I think, it is either the mobo, or the PW-120M power supply...
    Does anyone have a easy fix, or having same issues. Please post your experiences.
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    you have to put a on/off switch on the wire that is for your ignition wire on the ps. When you start the car with the switch off, the carputer will not turn on. When the interior of the car is warm enough, turn the switch on to boot the pc. Unless someone else has a better suggestion. I had the same problem last year in NC, temp got to 19F and the pc wouldnt even post.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    I thought computers liked cold conditions
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
    Elsewhere
    It's most likely the hard drive causing your boot problems.
    HDDs have fluid bearings. THey are sitting in oil, basically. When the temperature gets cold enough, that fluid becomes too thick to allow the platters to spin properly, so it won't boot.
    How about the Wiki?
    Feb 2005
    Denmark
    Quote Originally Posted by DarquePervert
    Well, It should boot but then give me an boot error, if i Am correct... It is not very often a HD will get the computer to stall like that.
    Oct 2005
    Bedford, UK
    If it is the HDD you could try getting a CF adapter and use CF to hold your OS. The would let the computer start heating up before you access the HDD.
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    So whats the lowest temp people have had their systems running at? Im jsut about to mount a PC in my Benz in Poland, where it gets to -25 C, and this is giving me some worries...
    Newbie kirill.krylov's Avatar
    Apr 2005
    Toronto/Canada
    I live in Canada and experienced the same problem. Usually an HDD’s (2.5") operating temp rages between +5C to +65C. Temps below 5 and/or above 65 will trigger a safety switch that prevents HDD from spinning.
    I have winterized my PC as follows. I bought cheap USB2.0 carrying case that I feed from PC’s power supply. It prevents voltage spikes during cranking and assures safe shutdown when engine is OFF.
    There are heating pads available on e-bay that RVers use to heat their seats, or other mobile heat pads for pets. Power varies from 15-40W. This is what. I simply wrapped the case around in the heating pad. To prevent HDD from overheating I’ve used a thermostat that works just like a relay, switching power feed on and off when necessary.
    Next step is to make sure you battery does not die (try to leave your heated sets overnight). 25W / 12 volts = 2 Amps. Canadian battery capacity is about 55 Amp/hrs, that will keep be heating pad for about 55/2 = 27 hours (after 27 hours battery is completely discharged). I’ve used solar panel and dual battery set-up separated by bunch of diodes to make sure that AUX battery gets the load and main stays idle. So far it’s been ok
    FLAC jbors's Avatar
    Nov 2003
    Try to use ext temp range HDD drives. Fujitsu and Hitachi have them. -20C guaranteed.
    Fujitsu: MHT2020AT
    Hitachi: <need to look>
    Car pc integration with ease
    Car mediacenter
    Feb 2005
    Denmark
    Quote Originally Posted by jbors
    Fujitsu: MHT2020AT
    As I said, I dont think is the harddrive that is causing the problems. Why should it stall the computer completely ?
    The computer won't boot at all...
    Personally I think is mobo related, but i'm not sure.
  1. Replies: 4
    Last Post: 08-09-2005, 08:49 AM
  2. DWW-700M/MTS12000 Motorized In Dash LCD Problems
    By techy101 in forum LCD/Display
    Last Post: 06-29-2005, 07:12 PM
  3. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
  4. cold weather problems
    By dbxxx in forum Newbie
    Last Post: 01-21-2005, 09:52 AM
  5. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 09:37 AM
