Results 1 to 4 of 4
Thread: My cpu is cr@p
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    My cpu is cr@p - turn it into a mobile cpu for free
    Just typed its number into google, never thought much of it before, its come back as a 1700+ palomino and 89 watts.
    That explains a lot.....
    Since I now want to change it, and maybe the mb, suggestions please.
    I want a full size mb with raid onboard, I plan to raid 2 CF cards to get the speed back that a simple CF card wont do. or raid 2 laptop drives.
    I use a kg7, or was it a ka7, so keeping that is an option. (133mhz fsb tops)
    So maybe just the cpu to swap, but these amd things are odd, lots of same speed with odd names, IE palomino, barton, thonton, then the mobile.
    Its an headache waiting to happen.
    Am I right in thinking mobile is best and thornton 2nd best option?
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    edit - just founf this guid to reduce power consumption
    http://www.tomshardware.com/cpu/20041001/index.html
    anybody want to comment before I try (and prob blow the chip up)
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    no, oh well I'm going to try it later today and I'l let you all know if it works.
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    If your m/b allows for it, you could reduce the voltage going to your processor. This will reduce heat and power without need for a new proc. Not saying it will solve your problem, but it very well may. I wouldn't go any lower than 1.25V, but I'd say try 1.35 first.
  1. COMMELL LV-667T w/ VIA C3 1.00GHz CPU INFO please
    By KF4ODQ in forum General Hardware Discussion
    Last Post: 08-10-2005, 03:10 PM
  2. High cpu usage when audio is muted.
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-23-2005, 03:51 PM
  3. Mobile CPU VS Conventional CPU ??'s
    By J-Fame in forum General Hardware Discussion
    Last Post: 02-18-2005, 09:25 AM
  4. WTB: Mini atx motherboard & CPu
    By jermkesler in forum Classified Archive
    Last Post: 02-04-2005, 11:31 AM
  5. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
