Results 1 to 10 of 11
Thread: Starting Pc via mobile phone.
    Newbie davebateman's Avatar
    Apr 2005
    Manchester, UK
    Hi all,
    Ive got a bit of a problem here. I was going to use a serial relay to start my laptop when my mobile connected to it got a txt. the problem is that ive noticed my laptop doesnt have a serial port... doh!
    Basically i want to be able to txt the computer and it send me back information or do certain things. Now I could connect the phone (Nokia 6310i) via a usb cable and that would be fine for the communication. The problem is then how to boot the pc from the phone.
    I considered running a wire from the com port used for texts on the phone to a realy which would trip my power cable. but then if i text it again i realised it would kill the pc.
    Im out of my depth here but is there anything i could use to do say an if statement? for example... 'if pc = off then power it' etc.
    Ive got a spare pcmcia port if that helps, and parallel. its not got a modem so i cant do wake up on ring and it doesnt suppose wakeup on lan.
    any ideas would be greatly accepted! cheers fellas
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    usb to serial adapters?
    Maximum Bitrate Rundell's Avatar
    Not sure if this will help you or not but there is a setting in Windows XP under Power Options Properties, where you can control through windows what the power button can do. So you can change that option and have it do nothing so your system won't turn off.
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Apr 2005
    Manchester, UK
    Quote Originally Posted by Rundell
    thats quite interesting, i will deffo look into that as then there is the possibility of changing how long you would press the button for. and thus a quick burst from a phone wouldnt change anything.
    oooh, i could have quick burst of power to turn it on as normal, and then a hold for 4 seconds to turn off. interesting, i shall research more but that makes a bit of sense. cheers!
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    I wanna try to do something like this...
    I've been thinking of a way to do this via WOL (Wake On Lan)
    Any Ideas?
    Peace,
    Rafster
    Apr 2005
    Manchester, UK
    right, my plan is now the following:
    nokia 6310 connected via usb to pc, a cut in the usb cable routes any data through a relay which if detected will flick the power line and start the pc.
    then after its started i can send txt commands to the pc.
    to shut the pc down i can text it too, no need for the relay.
    and to shut it down whilt im in there i just do it through road runner.
    woo.
    Jul 2005
    Quote Originally Posted by davebateman
    woo.
    Dave,
    Can you give us a better idea exactly what your doing/have done to set this up, as it's something that's on my "must do" list! How does the phone/pc work out what is a text to shut it down, or a text to do something??
    Any pics or diagrams would be very helpfull,
    Cheers in advance.
    MB870 / P4 2.4 / 512MB DDR / Pinoneer Slimline DVD-RW / 7200 SATA 120GB HD <- OPUS 150W
    Xenarc 700TS <- CNX-P1260
    FLAC sama's Avatar
    Feb 2006
    London, UK
    dave, is that a 6310i?
    if u have bluetooth, u can power on via cable, and talk via bluetooth. Might make things simpler to communicate via seperate channels. tho bluetooth maybe a little flacky.
    How about wiring the ringer to a relay? that way text's can be silent to ignore switching on via sms. and you could control via serial?
    just some ideas.
    Nov 2005
    UK
    woo.
    why not wire a second (normally closed) relay inline with the first and set this to open when the computer is powered up, that way the link to the power button is broke whenever the computer is on and any further texts received by the phone would not trigger the power button.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    hey DaveC thanks! you just solved how I will use the IBUS to power my car, rather than the ignition switch! That way when I use my keyfob to open the car, the pc can start powering up. nice 1
  1. Radio from mobile phone idea
    By couteau in forum Road Runner
    Last Post: 09-09-2005, 01:19 PM
  2. GPS vehicle tracking, any advise ?
    By paulfromholland in forum GPS
    Last Post: 07-01-2005, 03:42 AM
  3. sony ericsson phone bluetooth pc remote
    By streetknight in forum Input Devices
    Last Post: 03-20-2004, 04:44 AM
  4. interface cell phone to head unit through pc
    By Batmanatthenewb in forum General Hardware Discussion
    Last Post: 02-08-2004, 05:06 AM
  5. mobile pc
    By momo6383 in forum General Hardware Discussion
    Last Post: 11-25-2000, 09:54 PM
