I will name my first born after the person who makes this work.
Anyone know or have the circuit diagram of the Xenarc touch screen?
I would like to work developing an auto CCFL dimmer based on brightness of the environment. I saw this on an Avic this past weekend where the screen would dim or brighten depending on how bright it was inside the vehicle.
The Gamma method works but does not dim the CCFL so I'm looking at trying to get extended life on the CCFL using a photo diode and my current 8051 circuit. I imagine the current Xenarc design goes through some D/A conversion and it should be straight forward to get this working independant of the builtin firmware.
***EDIT looks like a similar project has been in discussion LCD Backlight Upgrade Autodimming control
Thoughts?
Chuck
Now there's a challengeOriginally Posted by PatO
all you need is a photodiode and a transistor
the xenarc's inverter displays varying brightness dependent on a pin that goes from 0 to 5v
Do you happen to know where this pin is located? The circuit is easy and I would like to make it adjustable through a Microcontroller I already use as part of my installation.Originally Posted by greenman100
Thx,
Chuck
Hmmm... I think I shall name him Mini-Greenman!
However, we must find this pin first...
there's a 4 pin cable going from the LCD controller to the mainboard. There's +12v, ground, the brightness, and a 4th pin that may be ground.
I could take a measuremnt and check
Thanks.
Maybe I will purchase another Xenarc to mess with instead of removing mine at this time. Would really be bad if something happened and I had no display for my vehicle.
I will order one and work on this. I think it will be easy, I think I may go the way of an OPAMP and Photodiode to adjust gain.
Thoughts.
Chuck
how did i miss this thread?
it's easy. You want a couple of pots. one in series and one in parrallel with a photocell. the inverter pinout is giiven in a thread somewhere.
Anyone have pics of this mod? I've killed things doing this type of work before, and I really really really don't want to kill a Xenarc!
