Results 1 to 2 of 2
Thread: Epia network problem
    Newbie Lucifer's Avatar
    Aug 2004
    Belgium
    I currently ran into some problems with my M10000 board. When I switched on my mini-pc, it coudln't get connected to my network. Yet, last time I ran it, it could. My network consists of a us robotics turbo router, to which I can connect with my other pc's. I also checked the cables.
    I re-installed xp pro (sp2), installed the drivers that came with the board, got the latest drivers from the net, installed those too, but no luck. The light at the back panel lights up, the green light stays on onstantly, while the orange one constantly flickers (non-stop).
    I have all settings exactly the same as my other pc's which connect without problems. Still I get no IP from my router (xp tells me I have limited or no connectivity)
    I'm starting to think my onboard lan is broken, can this be replaced, fixed? Or could it be something I overlooked? Any help very much appriciated!
    Thanks!
    Morex 3688 (Via MII10000 - 512Mb - 2,5HD 30Gb DVD+RW)
    CarTFT Motorized 7" In-dash Touchscreen
    CNX 1260
    Current Status: Skinning !
    Oct 2004
    New Jersey
    Lucifer,
    Bad news is you really can't replace the onboard LAN if it's actually "Broke"
    Good news is... The Green light signifies it see a good link and the Blinking Orange means it's getting/sees traffic. So I don't think the port is bad.
    What happens if you go to a command prompt and type IPCONFIG? Does it show the correct IP address scheme and correct subnet?
    If it doesn't try typing at a command prompt IPCONFIG /RELEASE then IPCONFIG /RENEW to see it pulls the correct IP address.
    Let me now if any of this works.
    Rob
  1. Orinoco Gold and EPIA board crosstalk/conflict
    By -zip- in forum General Hardware Discussion
    Last Post: 11-07-2005, 08:46 PM
  2. epia m-9000 bios update problem
    By saletel in forum General Hardware Discussion
    Last Post: 12-12-2004, 07:27 PM
  3. boot problem with epia m
    By jemmons in forum General Hardware Discussion
    Last Post: 10-24-2003, 07:16 PM
  4. VIA EPIA Mini ITX beeping problem
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 06-28-2002, 11:31 PM
  5. Need win98se full version help for a problem!!!!
    By jssaggie in forum Software & Software Development
    Last Post: 12-04-2001, 03:08 PM
