Results 1 to 4 of 4
Thread: Anyone ever try an M1 atx in a Cubid case?
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    anyone ever try taking out the pw60 from the cubid case and replacing it with the m1atx? i did some research and the pw60 is 160mm by 45mm and the m1atx is 165mm by 45mm. i am planning on buying a morex 3688 case with carputer assembled in it already for a friend and was wondering instead of buying the ****ty itps i can replace the whole powersupply..anyone every try this? will it work?
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Newbie krustydawg's Avatar
    Apr 2005
    I am running that exact setup. The only problem that you will run into is using the front USB ports the M1 kind of blocks the pins on the USB connectors. So you will have to carefully bend the pins up to get it to fit and still use the USB ports on the front.
    krustydawg
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    Jan 2005
    Chicago, IL
    so its feasible?
    Apr 2005
    Sure the mounting holes are the same it just wider than the stock 60W.
    Krustydawg
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. Think I've found the perfect Micro ATX Case!!
    By Anees in forum General Hardware Discussion
    Last Post: 03-16-2005, 02:27 AM
  3. i´m on search for the smallest case for micro atx
    By b7turbo in forum General Hardware Discussion
    Last Post: 07-04-2004, 02:52 PM
  4. fs: mastero mk-3.5 120w atx dc-dc power supply
    By infinkc in forum Classified Archive
    Last Post: 05-16-2004, 06:06 PM
  5. Epia M10000 in Cubid 3688 case... hard disk does not fit
    By Urinemachine in forum General Hardware Discussion
    Last Post: 04-29-2004, 03:52 PM
