Try to boot the system in "safe mode". If you get to display your desktop then, it could be that the monitor frequency is set too high.
That would cause the monitor to turn itself off during the normal startup.
If in safe mode everything works well, then set the monitor frequency to a lower setting, which is supported by your monitor.
Hope it helps.
LinkBack URL
About LinkBacks
