Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: SERIOUS Vibration Insulation
  1. #11
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    If you go with your plan of padding the box inside another box you might have some heat dissipation problems.
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
  2. #12
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    if you search the form, this has been discussed over, and over, and over, and over, and over again. Basically tons of people on here have had their harddrives go through hell, and have had no problems. I've driven on 10 miles of gravel road with my system right near the sub, no problems. People have been in accidents, their computer still running solid...etc. My hdd does have shock absorbant mounts, but their main purpose if to limin vibration noise between the hdd and the cooling bracket I have on there. The mounts came with my hdd mount.
    Pic of the mounts
    the hdd cooler itself
    PC Components:
    My work log
  3. #13
    Newbie hunterius's Avatar
    May 2006
    "We cannot solve our problems with the same thinking we used when we created them."
  4. #14
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Quote Originally Posted by BladeUK
    - Make an birch-ply case for the motherboard and components
    - Sit this inside another, larger case, which will be lined with closed cell foam to give a snug fit
    Actually, the box-within-a-box idea sounds like a reasonable idea. Define closed-cell foam...are you talkin upholstery cushioning? That sounds like a great idea...gotta keep ventilation in mind though.
  1. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-26-2006, 11:40 PM
  2. serious error
    By NYCdesignkid in forum Power Supplies
    Last Post: 02-02-2005, 09:26 AM
  3. Heat insulation
    By ryuandwings in forum General MP3Car Discussion
    Last Post: 11-16-2004, 07:58 PM
  4. problems from road vibration
    By seven10split in forum General Hardware Discussion
    Last Post: 08-08-2000, 11:47 AM
  5. is serious?
    By maromba in forum General Hardware Discussion
    Last Post: 01-18-2000, 07:23 PM
