Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 89
Thread: Wiring backup/Rearview camera -- can engine crank damage?!
  1. #41
    Jul 2004
    Quote Originally Posted by roadhog
    Why you little....! ok you explain it in more depth than I did.
    Oops I didn't even see your post lol...skipped right over it
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Jackboot
    Not surprising, as he mainly posts brown yeucchhy stuff
  3. #43
    Mar 2005
    Pomona, CA
    I wired my ebay bought reverse camera directly to +12v from the battery (switched of course).
    Problem I have, and is noted, is that the cameras typically requires a very clean supply, which the car does not have. Using car power gives some noise in the video signal. The cameras do say that "car power" is an acceptable input, so I am assuming that there is some built in over voltage protection.
    My plans were to always put a low current wide range input voltage regulator to power the camera. Something with 9-24v input, and a clean 12v out. These are pretty common, and run anywhere from $20-70 and are about the size of 2 matchboxes. I plan to do this the next time I have a desire to do some re-wiring.
  4. #44
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by sivart321
    siavrt: if you can point me to a source that carries those particular regulators please let me know.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #45
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Quote Originally Posted by Enforcer
    There's the door.
    Use it.
    & flog the rest on ebay
  6. #46
    Mar 2005
    Pomona, CA
    Quote Originally Posted by justintime
    I'll have to look again. I had them at work, and figured I would just use those.
    They were something like 6-24v input, 12v output at 3 amps, 83+% efficient and had a very clean output. I printed out the specs from their website online, but cannot seem to find them now. I was told the ones we had in house cost around ~$70, but I found some for considerably cheaper. I have also heard you can get samples for free.
    I'll let you know.
  7. #47
    Apr 2005
    Quote Originally Posted by StrataG
    Somewhat tedious depending on your car, but you could run 2 wires (could be 1 cable with 2 wires in it like speaker wire) from the trunk to your dash. Tap the reverse light and send it down one wire. Wire the switch up to that wire and also something that stays on while the car is running (you could tap pretty much anything in the fuse box). Then use the other wire going back to the trunk to trigger the relay. This will yield automatic trigger of the reverse camera when in reverse (in one position) and always on (in the other position).
    Strata, I re-read your suggestion just now, and I think you're on the money. With this solution, I wouldn't even need a diode
    If I read this correctly, what we are doing with this is making the switch decide whether the brake-light, or the constant 12V, will trigger the relay.
    I like this better than wiring both hot lines directly to the relay. I will follow that path, thanks. I might draw a diagram and post here to triple check with others shortly.
    2002 Honda CR-V
  8. #48
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    Wow this sucks, I spent like 10 minutes writing a reply after you pm'd me and somehow it never posted. I didn't have time to draw a diagram and don't really right now, but it shouldn't be difficult to conceptualize.
    SPDT Switch
    -----Inputs
    Reverse light -> switch (one side)
    Fuse tap -> switch (other side)
    -----Output
    Center of switch -> relay trigger
    Relay
    ----- Inputs
    Feed from switch -> Relay trigger
    12V positive from PSU -> Relay power input
    Matching ground from PSU -> Relay ground
    ----- Output
    12V Relay output -> Camera power input
  9. #49
    Apr 2005
    Strata dont worry about it. I have bigger problems thi minute. While testing the voltage of the rear light, I shorted them out, and now by car is acting up. I cannot see any blown fuses. OMFG I am going to kill myslef if I caused any damage LOL
    2002 Honda CR-V
  10. #50
    Aug 2005
    New York
    How is it acting up? Also, keep in mind you want to be using your reverse light, not your tail light (assuming what you meant my rear). Are all the lights out or just the individual one you were testing? If it's all of them, you likely just blew the fuse. Look up in your manual which one is for those lights. I've often overlooked blown fuses getting annoyed looking through all of them. Easier to just pinpoint the one.
  1. [REVIEW] In-Bumper Rear-view camera
    By RoyN in forum General Hardware Discussion
    Last Post: 12-30-2006, 03:42 PM
  2. Using a high farad cap to survive engine crank
    By lakorai in forum Power Supplies
    Last Post: 03-28-2005, 10:47 AM
  3. why is my backup camera not working with my capture card?
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-17-2005, 03:52 PM
  4. Replies: 3
    Last Post: 08-14-2004, 01:31 PM
  5. Opus and diesel engine crank?
    By bridqer in forum Power Supplies
    Last Post: 03-08-2004, 09:59 PM
