Results 1 to 10 of 15
Thread: Wierd HDD problem...
    Tainted Love Cris's Avatar
    Romania
    Question Wierd HDD problem...
    I have a 80Gb WD HDD, in a mobile rack, appart from the other one which suports the OS, and it run fine until yesterday...
    Windows doesn't see it. I can see it in BIOS, and in Device manager under disk drives. When I click Properties, it says the device is running ok. I click populate and it says it's not initialized... and cannot get the volumes out of it.
    At first I though I may have done something to the rack, so I tried running it straight from an IDE cable. That didn't worked, so I tried using a USB-IDE adapter. It sees the drive connected trough the USB, but under My computer, still nothing...
    I tried another HDD on the same system, and that runs just fine...
    I mean...WTFf???
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    Sounds like the drive can't read the disc at all, i.e. broken wire(s) between head and drive controller board. The drive controller initialises and reports back its BIOS info, but stalls when asked for partition info etc.
    Something obscure but easily checkable would be the power connector. Is it definitely getting both 5+ and 12+ on the controller board, i.e. no dry joints?
    Pure shot in the dark, just my 2 cents worth.
    Romania
    Quote Originally Posted by roadhog
    That's fine. I've checked all of this; the power connector, the IDE one. Tried it on another computer, and I still get this eror.
    Actually this drive was from another computer, and it still had the OS on it from the old one. So I put it back on the old pc, and it gives me a disk boot failure...
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    What do you see when you go to disk management? you might have to right click on the drive and import it.
    肚子笑痛了
    S60 Install
    Low Bitrate Enak's Avatar
    May 2004
    Hertfordshire, UK
    Sounds knackered.
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    maybe lost data off track 0
    Lez, more widely known as flez1966
    Romania
    Quote Originally Posted by jcdillin
    That option is not available...
    It seems that formatating it is necesary. In disk management the disk wasn't asigned, and I had to go through the same process now, as I did when I first bought it.
    btw, what's the difference between a basic and a dynamic drive?
    Romania
    Quote Originally Posted by lez
    Yes, it seems that all of the data has been lost on it.
    But my question is, why?
    Low Bitrate madmartigan's Avatar
    May 2005
    Canada
    Yup, she's pooched. Sorry amigo.
    Dont tell me to shut up, I'm Rick James ******!!!
    Jul 2005
    Hampshire UK
    Quote Originally Posted by Cris
    I wondered if the joint between the socket and the drive PCB could be suspect, rather than the cable.
  1. Wierd Civic Problem
    By nester in forum Off Topic
    Last Post: 10-09-2007, 05:44 AM
  2. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 06:09 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. USB Hdd cannot be seen
    By takissd in forum Off Topic
    Last Post: 06-06-2005, 10:35 AM
  5. Computer Building Problem
    By 0l33l in forum General Hardware Discussion
    Last Post: 05-09-2005, 02:52 AM
