if you are having a problem at 39F, then it is not due to cold temps
Look for a power issue.
My set up has been in the low teens (F) without an issue.
Ok I know this has been posted a coupel times before but can never seem to find it in teh searches. Anyway I still can't beleive more people do not seem to have this issue.
I changed my pc to run on a 2.5" laptop drive this year to see if maybe I only had a issue because I had a 200gb 3.5" drive. Anyway just went to get doughnuts and its 39°F and it failed its test.
Anywho just wondering what has everyone doen t ocurb this issue and feel free to yell at me that this has been posted before but its been a while and dun see why it can't be revisited.![]()
Toyota Prius w/ NAV system and a 30gb Ipod :)it never crashes and always boots up.
TruckinMP3
Read the FAQ!
I plan on using a 2.5 drive with UBS2 hookup that I can carry with me when needed.
It actually uses 2 ports, one for power and one for data. Nice touch and it is smaller than a pack of smokes. I will post a pic if I ever find one.
Dont tell me to shut up, I'm Rick James ******!!!
it wokrs fine when its above 42°F but below it boots once starts to load windows then poof reboots the colder the more times it does this below 20°F the old drive woudl not even budge jsut wen tto disk read error new drive hasn't seen that yet and still 2 more weeks till I see those temps. I have one of those usb 2.5 drive kits to but my board turned out to not have usb 2.0 so never worked had to goto the ide to 2.5 converter thingy.
Ahhhhhh crappy. And a USB 2.0 card wont work in a boot sequence if I remember correctly. Perhaps a mobile rack? You can integrate them into a dash fairly easy and have it looking sweet. I little dremel love and resin works wonders. Then you can take the drive with you when necessary. I live in Souther Ontario so we get cold here too and this is a big issue for me. Hope it works out for ya.
So as I thoguht before best solution still is taking hard drive with you to keep it warm. Has anyone tried a liek 4gb flash drive to run and boot os then drive woudl possibly be warm enough once puter is booted?
I have a similar issue. Everything worked fine the first several months but one night we got down near freezing (I live in South Louisiana and didn't think too cold would be my problem) and since then any night that it gets below around 60 causes me issues. My system will boot after it warms up but I didn't build in a seperate power switch so I either boot to the BIOS and watch the system temp or I have to turn off the truck at a red light. I have just run into the issue recently so I don't know what I'm going to do...
JoshB [BadPakt]
TruckPC [||||||||||] 90% (Tweaking Software)
FrodoPlayer / Lilliput / Opus 150 / AMD Sempron / PowerMate
Roady2 ((XM)) / Sony W600 / Bluetooth / Ford Ranger EDGE
There seems to be a similar thread that just started. Bunch of guys from Canada and the likes trying to deal with thirty below temps...
Cold weather (-25c and lower)
JoshB [BadPakt]
Want to:
