Results 1 to 8 of 8
Thread: Hibernate takes longer than 45 secs, big problem!
    Nov 2004
    I have the chip that cuts main computer power after 45-seconds of the car cutting off. I recently just changed my setup and now with 512MB of ram it takes a little bit longer than that to hibernate... meaning my power gets cut before it completes the hibernate.
    Without having to downgrade to 256MB which will hibernate faster but my system runs so smooth with 512MB ram... can I turn off unnecessary processes/system stuff to make Windows hibernate about 5 seconds faster?
    All I need is about 5 seconds, don't know if I can pull off that much savings by just turning off stuff but any help is greatly appreciated.
    Just so you know my system specs: AMD XP2500+, 512MB ram, 7200rpm HDD, Win XP Pro.
    Jun 2002
    Malaysia
    Going to be tough, because hibernating means copying all the contents of RAM into the hard disk, the bigger the RAM the longer it takes.
    You already have a fast rpm HD, is there a faster HD? I dont know, S-ATA or RAID are they faster?
    Elsewhere
    Quote Originally Posted by davem
    Yes, you can, although I don't know how much of an impact it will make.
    I suggest running MSCONFIG and removing anything unnecessary from startup.
    You can also go into Services and shut off services you dont need/use.
    If you disable enough unused stuff, you could likely shave 5sec off your hibernate time. No guarantee, though
    How about the Wiki?
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    minilogon for me shaved a good 15-20 seconds.. it skips the whole "pretty windows screens that say "logging out, saving settings, and preparing to hibernate" .. it jumps right to "hibernating"...
    make sure to get the ctrl+alt+ delete program too
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I am really suprised that it takes that long, I would look into disabling hardware (especially USB devices) one at a time to see if one of them is causing the holdup.
    Definately look into extra services that you dont need.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    Nov 2004
    Thanks everyone! I will try this out and report back with my results.
    Neon_eddy, do you have a link to the minilogon program? What's the CTRL-ALT-DEL program?
    Nov 2004
    Ham Lake, MN
    ftp://files:files@69.180.167.128/sof...leminlogon.zip
    read up on it in the forums here first.. it basicly logs you on as the "system" user.. the normal CTRL+ALT+DEL won't work without the extra program.. I think it's included in the zip file I linked to.
    Shawn
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Minlogon should help, but it has its drawbacks. You may have ACPI problems as well, and need yet another program if you ever want your SDC to shut down your pc instead of just hibernate. I still think it's worth it though.
    I would start by researching the services you have running. You likely don't need half of them for a cap pc. Disable or set to manual depending on importance.
    It's strange that a system with your specs takes so long. Is your hdd low on space and extremely fragmented? I just timed my hibernate time, it's four seconds. Of course, I've done a bit of OS optimization.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  1. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  2. almost done but one big problem
    By joeblaga in forum General MP3Car Discussion
    Last Post: 09-30-2005, 09:48 PM
  3. Is there a Problem under resume from Hibernate?
    By bry21317 in forum FreeDrive
    Last Post: 07-10-2005, 10:33 PM
  4. what to do if hibernate takes more than 45 second
    By niclus in forum Power Supplies
    Last Post: 04-06-2005, 11:52 AM
