Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Using flash drive as your primary hard drive?
    Jul 2005
    We have problems with cold climate around here. I am wondering if I could use a 4 gig flash to run WIN 2000 Pro, Roadrunner and GPS? I would use an external HD to house all music etc. This way I could take the HD in and out of the car. Is this possible? If so can someone point me in the correct direction. Thanks
    Feb 2004
    Yes, you certainly could.. I'm currently running XP Pro on a 1G CF card.
    See here for instructions on how:
    http://mason.gmu.edu/~sfiorito/eXPinstall.htm
    You'll want to use the Enhanced Write Filter (EWF) trick with compact flash to reduce writes, otherwise it won't last very long.
    If you also want to use the Hibernate Once Resume Many feature, you'll need to disconnect your external HD when setting the hibernate point.
    Nov 2005
    I was also wondering that. I live in NC and sometimes the inside of my car can reach temps of over 120 and under 15 (like this morning). What can be done for a temp regulator for something like this if you didn't want to go to a flash drive?
    -Villain
    Feb 2004
    Quote Originally Posted by Villain
    -Villain
    Tricky... check the technical specs for your hard drive or CF card for its operational temperature range.
    For example, my 2.5" laptop drive that I'm using is a Samsung 40GB disk, # MP0402H.
    It's operational temperature is between 5C and 55C, or 41F and 131F.
    It's non-operational temperature is between -40C to 70C, or -40F to 158F.
    So for a drive like this, the temperature must be above 41F for the drive to spin up.. it's a mechanical limitation. But it can withstand up to -40 below when it's not running.
    2.5" laptop drives are usually much more robust than 3.5" drives.
    Nov 2005
    So basically I start my car in the cold weather and my drive goes bye bye. (I'm sure one or two times MIGHT not hurt it, but it's bad to do over and over again).
    I guess I was thinking of some sort of thermostat on the PSU so that the PC doesn't start unless the temp is in a specific range.
    Other than that, I'm left with cooling fans on a thermo for the summer and what... an electric blanket and a power inverter for the winter...
    Dunno. Thanks for the help though.
    (Didn't mean to hijack the thread man, sorry)
    -Villain
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    I'm running mine from cf, running read only so I don't have to worry about writes
    Aug 2004
    How do you run windows read only? Could you elaborate a bit... ie what are the limitations?
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    You could take the hard drive in an out of the car and not use a flash drive
    This is what Im planning to do on my next install
    FLAC SFiorito's Avatar
    May 2004
    You have 2 options: use flash (which requires EWF, see above for the link to my instructions) or use an external USB hard drive which you take in and out of the car with you. Check the WinNT forum for a link to instructions. I haven't had a chance to do it myself yet, but it seems like others have used it successfully.
    May 2002
    Ohio
    Quote Originally Posted by Vinister
    Didn't know you were limiting to windows. I never did get it to work completely read only, played with the embedded versions for months before switching to Linux then had a working system in an evening.
  1. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  2. hard drive head crashing?
    By the4ork in forum General Hardware Discussion
    Last Post: 03-06-2005, 12:40 AM
  3. Ultimate Hard Drive Mount or bad idea?
    By rockthevolvo in forum General Hardware Discussion
    Last Post: 08-29-2004, 05:22 PM
  4. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
  5. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 12:39 PM
