Results 1 to 4 of 4
Thread: EPIA M10000 after bios flash NO VIDEO! help!
    Aug 2004
    i downloaded the newest bios flash from via and the install seemed to go fine, it said it was complete and to hit f1 to reboot... i did this and the video never came back up. i tried different monitors, and s-video there is no video in the bios what so ever.. i tried reseting the cmos and pulling the battery with no luck. any ideas?
    Oct 2005
    The via website where you downloaded the BIOS says you need to have the VGA driver also installed, not sure if that is the issue, but best of luck.
    Nov 2005
    One thing that I've learned over the years is to NEVER do a BIOS upgrade to hardware on anything that I'm not willing to throw in the trash. Seems to work perhaps 1 out of 3 times. 2 out of three times something goes wrong and I'm left with nothing but junk. Hope this isn't the case here.
    Oct 2005
    Quote Originally Posted by pumori
    That's just bad technique 99% of the time. I've never had a flash go bad.
    Quote Originally Posted by pir800
    What bios version is it? I know that 1.6 created memory incompatibilities for many with rev. b boards. Try resetting the CMOS, letting the board sit for about a half an hour then try again. As soon as the video pops up go into BIOS and reset the memory setting to manual speed, drop it to 100MHZ and 2.5T. Then save and restart. Make sure you do it quick though because mine would drop video pretty quickly and would not come back until I reset CMOS and let the board sit again.
    Progress: [xxxxxxx---]
    All components purchased (AGAIN!).
    2 Lillipoops lilliplopped, working on #3 (DWW-700M This time).
  1. VIA Mini-itx M10000 Bios Upragde
    By hafster in forum Newbie
    Last Post: 02-25-2006, 01:15 AM
  2. FS: Epia M10000 and M1-ATX both almost new
    By CapitaineFritz in forum Classified Archive
    Last Post: 10-20-2005, 07:22 AM
  3. FS: Epia M10000, Opus Case, 512 ram, 30gb HD
    By Darek85 in forum Classified Archive
    Last Post: 07-26-2005, 11:29 AM
  4. Epia M Video Playback
    By blazinlow in forum General Hardware Discussion
    Last Post: 05-30-2005, 08:21 PM
  5. Epia Bios
    By Navigator_82 in forum Newbie
    Last Post: 03-25-2004, 03:17 PM
