Results 1 to 7 of 7
Thread: XP-M Pin Mod Question... DP?
    Dec 2001
    I was going to use an MSI K7N2GM-V which of course doesnt let you set anything like vcore or multiplier...
    If I use
    http://www.ocinside.de/go_e.html?/ht...md_pinmod.html
    to do the pin mod and use a vcore of 1.475 (as close to 1.45 as possible) do I need to cut the L11 bridges if its an xp-m 2400 or do I simply need to put the wires where they go?
    On the website it says it works for xp etc but it doesnt state anything about xp-m processors. I was hoping someone like DPO who has done it already has an answer to this!
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Just put the wires where they go... I've done this mod many times.
    Dec 2001
    yeah but I have an XP-M not an XP and was wondering if I need to cut the L11 bridges to change the voltage.... to 1.475
    Elsewhere
    1) I haven't done the pin mod on that particular motherboard.
    2) I used the pin mod to set the vCore voltage to the lowest that was available on the Pin Mod Tutorial website, which is 1.475. It works just fine, albeit a bit hitter than if I were to run it at the SPU spec voltage of 1.35.
    3) Don't cut any bridges ont he XP-M. That's only necessary for non-mobile CPUs which aren't already unlocked.
    Sorry for the delay in reply. I spend the holiday weekend unplugged, and it was refreshing.
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Don't bother with Vcore and other ****. Just put the wire for the correct FSB, and you are done.
    Read up: FAQ Tutorial: Wire/Pin Mod for Mobile Athlon
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2001
    Yeah I actually have that page added as a bookmark but I wanted to make sure I could change the voltage to run the things as cool as possible... Mostly because running it with so much more voltage makes a lot of unwanted heat!
    Sep 2003
    Beach City, Socal
    If you find a way to pin mod it to have it running at lower voltage, let me know too. Well most of XP-M users will be happy
  1. "Welcome" screen on XP question
    By carpcnoobie in forum Newbie
    Last Post: 03-24-2004, 04:20 PM
  2. XP Keyboard Question
    By Altimat in forum Software & Software Development
    Last Post: 01-06-2004, 08:33 AM
  3. just reinstalled WinXP......have one question..need a little help.
    By guitar333 in forum Software & Software Development
    Last Post: 10-15-2003, 05:34 PM
  4. Probably a dumb question, but do I have to actually buy XP?
    By -al- in forum Software & Software Development
    Last Post: 09-28-2003, 03:53 AM
  5. Windows XP Hibernating Power Question
    By Rom in forum General Hardware Discussion
    Last Post: 08-01-2003, 11:59 AM
