Results 1 to 6 of 6
Thread: Fusing XMD1000
    Constant Bitrate reiner15's Avatar
    Mar 2005
    Michigan
    Fusing XMD1000
    Hello all,
    After burning up my previous unit, I want to put a in-line fuse as to make sure it doesnt happen again. I was wondering what possible solutions are out there for this since there are no 12v fuses. Do I use a 15v quick blow? I saw a picture of someones cable with inline fuses but they didnt mention how they had fused it.
    My Site: http://www.reinerweb.us
    My Car : http://members.cardomain.com/reiner15
    Car Computer Alias - TekPC
    Current Progress - - Brainstorming
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Fuses are for stopping too much current, ie Amperes. Not voltage. Typically, fusing a power cable is to keep the cable from catching fire, not to protect the equipment powered by it.
    Elsewhere
    Correct me if I'm wrong...
    But if the current is too high and it blows a fuse, the ciruit is severed. That would prevent the excessive current from reaching the device, thus preventing damage to it... Or is my logic just completely f-ed up?
    How about the Wiki?
    Newbie jaak's Avatar
    Mar 2004
    Toronto
    1/2 fuse amp is probably fine. I just fired up mine off my benchtop power supply and it's drawing 1/4 amp right now...
    There's a diode in the XMD1000 that will force an external fuse to blow if you connect the power backwards, thereby protecting the unit.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by DarquePervert
    Just somewhat f-ed up For all intents and purposes, current flows through the entire circuit simultaniously. So the fuse won't blow 'before' the current 'reaches' the device. Now, a fuse could protect the device if the device can withstand the high current for the time it take the fuse to blow (which is basically what's going on in terms of protecting your wires) but this is rarely going to be the case where sensitive electronics are concerned.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    yes but most devices can withstand too much current for the split second it takes the fuse to blow
  1. Fusing cable....
    By Psychobiker in forum Power Supplies
    Last Post: 09-22-2005, 01:33 PM
  2. Xmdirect Xmd1000 Question???
    By (6) in forum Hardware Development
    Last Post: 06-02-2005, 03:49 PM
  3. FS: TERK XMD1000 with XMDirect cable.
    By BoyNextDoor in forum Classified Archive
    Last Post: 05-29-2005, 10:57 AM
  4. New XMD1000 Not Working!
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 01-29-2005, 01:37 AM
  5. XMD1000 locks up my carputer.
    By R32 JUhl in forum General Hardware Discussion
    Last Post: 01-25-2005, 10:41 PM
