Results 1 to 10 of 19
Thread: Instantaneous Bootup Solution
    Nov 2005
    Has anyone tried using the Gigabyte i-Ram? I'm still in the planning stages at the moment, but this looks tasty.
    For those who don't know, it's a PCI card that can take up to 4 gb of DDR ram, which is battery-backed with an onboard LiIon, and has a SATA connector on it. It shows up to the OS as a hard disk, (up to 4gb) but it has a constant, sustained transfer rate, both read and write, of ABOVE 130meg a seccond. Looks interesting
    I know this is a bit odd for my first post, will do more later. I'm installing a Dual PIII-800 system if i can power it well enough. It's the quickest spare board i have around the place. Going into a Mitsubishi Nimbus.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    One problem I see is that the battery pack takes 6 hours to charge and then it only lasts 16 hours.
    Nov 2005
    I believe that it holds it's charge if the (desktop) pc is plugged into the wall. Presumably it's trickle charged from the mobos standby voltage? I will pick one up and see when i get the chance.
    I would still use a hard disk for data, movies etc but for the OS i'd like one of these. i'd make a backup bootable ghost CD every now and then which could be booted off on the roadside to restore the iram.
    Anyway, i'll post results next year. Can't do car PC till then, have to get my radio controlled lawn mower finished before christmas. Not enough money in my piggy to do both yet.
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    This wouldn't give "instantaneous boot" though. Going through the BIOS boot is by far the longest part of my cold boot time. Other motherboards are probably faster.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Are you talking about hibernating to that drive? or Putting the system into standby using that card?
    Also, depending on the voltage of the li-ion battery you might be able to toss the oncard battery and use your vehicles battery.
    Or putting the whole OS onto that drive?
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Fusion Brain Creator
    Mar 2005
    that drive doesn't help much
    at best it's 2x faster - and you still have CPU limitations to deal with
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Quote Originally Posted by darwiniandude
    Anyone else picture "Honey, I Shrunk the Kids" when he said this?
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I really doubt booting with the iram is going to be faster than resuming from sleep. And since you have to be trickle-powering RAM either way, you might as well sleep - faster resume and save yourself $$.
    It's cool, but unless you need fresh boots, I don't really see any advantage.
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Its boot up time regardless of hybernation or not it's gonna be substantially faster; the "only" limitation and its a big one, is that it needs to be constantly charged!
    Boot up time and application performance are substantially better.
    But if reliability is a factor for you, then this is too early for CarPC...
    08 Lincoln Navigator www.mobiteklink.com
    Sep 2005
    San Luis Obispo, CA
    Quote Originally Posted by MobiTekLink
    Actually I prefer when things don't work some or all of the time.
    It's more of a "surprise" then when it does!
    -arebelspy
  1. CF vs HDD Bootup Times
    By Willow in forum Hardware Development
    Last Post: 09-26-2009, 06:47 PM
  2. OBDII Diagnostic Solution for $64 (+shipping)
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-11-2007, 07:54 PM
  3. a serious solution
    By sohaibma in forum Power Supplies
    Last Post: 04-06-2005, 03:44 PM
  4. Help me pick a solution please
    By electron in forum Newbie
    Last Post: 09-14-2004, 01:02 PM
  5. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
