check display settings in bios....then check display settings for your OS
Hi all...
I got a huge problem, and i CANT figure out what, and where the problem is...
I have bought, Some hardware, for my CarPC here is the list:
ITX Motherboard: VIA Epia-M10000N, 1000 MHz, Nehemiah
Memory: Kingston 512 DDR 3200
HD: Seagate ST94813A, 40GB 2.5", 5400/8192
DvD Drive: QSI Combo Drive, CDRW - SBW-243
Case Whit PSU: Morex Cubid 3688, Black
And to monitor the whole system, i have bought a LCD Screen, Touch + VGA, from CarTFT.Com, and its a CTF-700
And now, to the problem..
My Computer, is actually working fine, and have configured whit software over several days.. And Today, i just got my touchscreen, from CarTFT, to monitor the whole thingreally nice.. Or..?
When i plugin the monitor, and try to turn on the computer, it disagree, it will not response.. The turnoff LED is making a small light, and shut off again, 0,1 mill sec. It will not turn on!.. but!, when i take the monitor out, it turns on correct, hmm? - And now.. when i try to plugin the monitor when to carpc have booted up, its shutsdown again.. its get a blackout.. the whole computer..!
After i have tried to do lots of things, i thought, does the monitor work at all? so i tested it on my regulare computer, HomePC, and it works fine!!!...
And the CarPC Computer, is allso working fine, whit my Home 19" monitor... So what can i do? both things work, but just not together...?
The CarPC, gets power, from the PSU there followed whit it, and allso The Monitor, from CarTFT.Com, each hardware, got there own... powersupply...
BG Tommy Christiansen, for god sake, plz help me, im going nuts over it...
// Tommy Christiansen (Denmark) - Vectra B
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAMold carPC
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
Originally Posted by Sympotonic
I know it is probably a translation issue, from Danish to English, but where is the Monitor receiving power from? Is it the same power supply for the CarPC? If it, try powering the monitor from another source while connecting the monitor to the CarPC, and see if that changes anything. It is possible, though unlikely, that the Monitor is too much for the CarPC power supply, and that is causing the computer to shut down.
Michael
HI Michael, and thx for the words.. you were right, translation problem hehe. the monitor have its own powersupplu, and allso the carpc, have its own.. so got other ideas `?
Try the carpc powered from the car and screen powered from a main supply and see if it works .... it may be a power problem in that the car can't power everything.
Just what he said.Originally Posted by ITL
It is a very strange problem. I don't think I have ever heard of something similar.
Is the computer actually turning off or shutting down, or is it just that the screen doesn't display a picture?
Are you connecting the VGA cable, or are you using the NTSC/Pal RCA connectors?
Michael
Gobby: none of it, is connected to the car.. i have the whole system right here at my desktop... i thought, it was a good idea, to test the system here at home, before i conected the whole system to the car hehe... The Monitor, and the CarPC Case, both come whit powersupply, to 230 ACV, and 12V Car, so i have just connected it all here at home, whit the 230-12 AC-DC adapters, to check it... but it dosnt work! :/
Michael: The screen is not turning of, the whole computer is shutting down, be active on this tread later this evening? i will record whit a video camera, a clip in 1-2 minutes, and stream it on the net, so you can se my actually problemi post the link in here later, when i come home from work
BG Tommy Christiansen...
weird...
500+ full albums
4,000+ video games
are any usb devices working? Those Epia-M10000 are known for blowing their caps...and have been known to cause USB issues similar to this.
PC Components:
My work log
try removing the DVD drive and all unnecessary devices (USB, etc) and see if thats any better. Check all of your jumpers on your drives, devices.
500+ full albums
4,000+ video games
