Results 1 to 5 of 5
Thread: Power switch question
    Nov 2003
    Olympia, WA
    ...maybe a simple question, but I want to run a switch from my mobo and mount it on my dash somewhere that would turn the power on/off to my pc. What kind of switch do I need. I was using the hacked power button from an old tower. I thought I needed a momentary switch but that didn't work so well.
    The switch would run to the pins on my mobo if that helps.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    A normally open momentary switch.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    If the cable run is long, you might get better results from a relay and switch.
    TruckinMP3
    Read the FAQ!
    Nov 2003
    Olympia, WA
    Quote Originally Posted by binary.h4x
    It's actually called a 'normally' open momentary switch?
    Jun 2003
    Fairfax, VA
    yup
  1. PS2 used as case and working PS2 reset/eject switch as power and reset
    By Silentbob343 in forum Hardware Development
    Last Post: 09-07-2005, 11:09 AM
  2. Opus 90w power switch wire connection question
    By Tim97rs in forum Power Supplies
    Last Post: 05-13-2005, 08:37 PM
  3. Switch letting power through
    By veetid in forum Power Supplies
    Last Post: 06-08-2004, 02:09 AM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  5. question for aaron, or anyone, about power switches
    By daver in forum Power Supplies
    Last Post: 10-28-2001, 02:02 AM
