Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: HDD Heater for sub-freezing climates - How much intrest is there?
    Low Bitrate nrls2000's Avatar
    Oct 2004
    Nebraska
    Creating a bolt on solution to keep hard drive above 60 degrees F.
    Thermostaticly controlled plate will bolt up to the bottom of most standard
    desktop HDD's. Not an adhesive pad heater.
    Preliminary tests show:
    consumption
    3.5-4 amps max at 12 volts (only during heating stage, current draw at idle is nominal)
    heat transfer rate
    15 F to 65 F = 1.5 min. (at the bearings)
    demensions
    .5" x 4" x 5.75"
    I have searched and found no acceptable bolt on solution.
    (open to alternatives) Otherwise...Is anyone interested?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    extremely interested.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Raw Wave
    Jun 2004
    On the beach
    I've been looking into this myself recently due to cold temperatures but so far haven't got very far.
    Woodbridge, VA
    Blog Entries
    32
    right now all i'm doin is blowing a heater fan thru the intake and warming the aluminum case and the hard drive in turn. Not very efficient and it still takes 10 mins to boot
    Jan 2005
    Phoenix, AZ
    For the right price, absolutely
    1998 BMW M3
    Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    whats wrong with an adhesive pad heater from a mirror?
    Peltiers ?
    Lez, more widely known as flez1966
    Jun 2005
    Michigan
    I would definately be interested. However, can this be made a little more general so different sizes could be available? I'd also like to heat my GPS (doesnt lock until warm) and maybe a 2.5" HD
    Oct 2004
    Nebraska
    Quote Originally Posted by lez
    Peltiers ?
    Those are ideas I considered, however I found to purchase heating pads new gets upward of $40 (in order to get the wattage necessary for sufficient heat transfer in less than 3 min.). Peltiers also seemed costly.
    My goal is to have a one piece, thermostaticly controlled bolt on solution for less than $50.
    Oct 2004
    Nebraska
    Quote Originally Posted by rsd212
    Yes.
    Give me demensions needed, desired temperature range, and enviromental clearances.
